Hi, i have a Series 1 R33 Skyline, ive got my new boost controller but i don't want to hook it up till i replace the SMIC with a FMIC kit because its so hot and humid in darwin. I was talking to a guy at Autobarn and he confused me about brands etc. I then read a Fast Fours magazine which was alright, one thing in the mag i noticed was;
A spokesman from Hybrid said with a FMIC kit to suit an R33, they have seen 30-35kw increase from replacing the SMIC with a Hybrid FMIC kit on a good nic RB25DET, this was also based on the cars being completly stock, no exhaust, intake mods or anything.
Other people have told me that a FMIC won't increase power and i might loose power if i get an FMIC kit that has a high pressure drop.
Now atm i am running stock boost, when i get the FMIC kit i wanna run 10 pounds on the stockie. After i get some more money and stop prettying up the car for the Mrs, i want to get a smallish turbo like a HKS2350, bigger pump, injectors and power FC and i want to run about 15 pounds.
I want to ask the experts :P, what brand of FMIC kit should i get, will i get any performance gain or loss & how Plug and Play are the FMIC kits as they state they are.
https://www.sau.com.au/forums/topic/94686-wanted-info-on-front-mount-for-r33/
you will not gain or loose any power by fitting a FMIC and changing nothing else. What you certainly will gain however is more throttle lag. the time taken from when you press the accel pedal to the time the throttle body see's positive pressure. this is because you now have to fill all the extra pipework and the bigger FMIC core. you wont make any more or less power as you aren't putting any more air through the system. airflow makes power and you haven't changed that. you've changed the size of the inlet system (larger core + pipes) but haven't pushed anymore air through. sure the air has less heat charge but its still the same volume.
a good idea if you wish to avoid having the throttle lag problem after it is fitted is make another change at the same time, such as turn the boost and do a 3" turbo back exhaust. if you do this the outlet system can flow more air (less restriction) and the upped boost pressure will flow more air (providing exhaust will permit it). most people assocaited this with "a fitted a FMIC and gained 20rwkw" type of hype etc. i dont think brand plays a massive role in a FMIC core, they are all metal with just a particular tube and fin or bar and plate.
do a search on both to find out which is better for your use. a GTR second hand one is plently and good for upto 300rwkw so it will suit your needs and be had cheaply and should at least mount up somewhat closely as its based on the r33 front.
remember that airflow makes power not boost. running 8psi means nothing, flowing more air than you currently are means more power
thanks man, i already have a 3" exhaust cat back, need to get a new dump pipe so it's 3" all the way.
Would it be worth buying a genuine Hybrid FMIC kit from Autobarn etc for $1000, or a cheap knock off Hybrid kit off ebay for $600. The Mrs want's the Hybrid kit cause its got the 'shiny pipes' as she calls it, and it's half her car so i got to do they shiny bling stuff.
Sorry about the stupid questions, owned suzuki siwft gti & nissan exa before the skyline, so i don't know shit about rwd turbo's.
i would suggest looking in the group buy section, there are always on group buys on FMIC kit's so you should be able to save some dollars there. get a 3" split dump from BATBML (under for sale, business trader area) and that will be a perfect dump pipe for your needs. it's a dump and front pipe in one. make sure you have a good flowing cat also, this will help in taking off back pressure and flowing more air out the exhaust
Yeh i installed my FMIC last week, I only have a pod in heatsheild and cat back exhaust and havn't increased boost yet, the power gains were little to none. In my book the FMIC was installed to set the car up safely to run higher boost.
when i had my FMIC installed i did notice a smaller delay when pressing the accel pedal so the theory re: throttle lag increase does hold truth and its not some front facing plenum myth.
depends on labour taken and amount of hours involved. i paid $1200 to have a no brander hybrid core fitted. the core was only $350 the labour and pipework and welding (all stainless) was what cranked the pricing up. and also labour to cut the front bar and make it all fit
Hey man,
These are apparently genuine hybrid and a couple of hundred cheaper.
http://www.skylinesaustralia.com/forums/in...showtopic=90632
Should only cost 300-500 bux to get it installed. when i installed mine i didn't really notice any major change but i'm waiting to get it on the dyno before i put up the boost above 9psi.
Check out the link anyway
Since I installed my hybrid fmic, there was definately more power, no change to turbo lag & my car stopped backfiring so much. :P When it was with the stock one, it would pop on 90% of my gear changes, fitted that & now it only does it when the revs get high, and very occasionally whenever it feels like it.
I installed my fmic with custom pipework 2 weeks ago, took me (very unexperienced) a total of around 10hours to get everything measured up and perfect.
I bought the Apexi intercooler with same side return end tanks, off ebay. 2ndhand but top condition direct from Japan.
I noticed more power, but the tune on my SAFC is now way off, as Im using a heap more fuel. Going in to the shop shortly for a full fuel system upgrade, and more tuning parts.
Ok then, it feels to me like there is a little extra 'kick' there.... in fact Im sure there is. But at the same stage Im sure a fair bit more fuel is being thrown thru the system (around 20% more judging by my fuel guage).
Getting retuned next week on the dyno, with more fuel & air mods......
Paul correct me if i'm wrong, but you may be adding more area to be filled by the turbocharger to fill the system with a FMIC, but if the air being pushed into the engine after the Frount mount would have a lower air temperature, and therefore would also have more molecules per area etc?
Ie. Under the same principle that your car seems to run better on a cold night?
Taken from Autospeed website: Issue 12: http://autospeed.drive.com.au/cms/A_0084/article.html
'When a turbo or supercharger compresses air, the air is heated up. While this hot air can be fed straight into the intake of the engine (and often is), there are two disadvantages in taking this approach.
Firstly, warm air has less density than cool air - this means that it weighs less. It's important to know that it's the mass of air breathed by the engine that determines power, not the volume. So if the engine is being fed warm, high pressure air, the maximum power possible is significantly lower than if it is inhaling cold, high pressure air. The second problem with an engine breathing warm air is that the likelihood of detonation is increased. Detonation is a process of unstable combustion, where the flame front does not move progressively through the combustion chamber. Instead, the air/fuel mixture explodes into action. When this occurs, damage to the pistons, rings or head can very quickly happen.
If the temperature of the air can be reduced following the turbo or supercharger, the engine will have the potential to safely develop a higher power output. Intercoolers are used to cause this temperature drop.'
Edited by insu
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
