how ya going guys, i was just wondering if anyone on here has had to have their car exempt from compliance? and if ya have or know anyone that has do you have any advice? helpful tip/hints to help me get through. cheersguys and thanks for the help!!
https://www.sau.com.au/forums/topic/95045-exempt-from-compliance/
I don't really understand your question?
Almost all cars have to meet ADRs to be registered.
If it is a 15yo or personal import, an engineer can confirm this
If it comes in under SEVS it is up to the complier to confirm it
If it is rally import it does not need to comply.
But this all depends on what the import approval was in the first place?
i had to do the exact same thing, in fact I was actually going to look at the car you bought but the dude never answered so i ended up getting another GTR in Vic.
If you've got any specific questions pm me and i'll be happy to pass on what happened to get my car through.
tom
yeah got no complance plate under the bonnet. apparenty it wasnt fitted(the car came in under the 15yo rule) i have the engineers certificate and import approval. and some peice of paper that i had to sign (buyer and seller thing) when i got the car.
15 year old cars don't get compliance plates... they'll have an australian VIN number stamped onto the chassis or rivetted onto it, which should come up on the system though. If you have an engineers cert and the engineer is recognised by your local road transport authority, then you should have no issues.
We bought an 89 GTR from Sydney. As 89s do not come fitted with the green compliance plate, the car had to undergo a full inspection at Regency, along with us having to show proof of compliance (i.e engineer's certificate) and import approval papers.
Regency provided me with an Application for Exemption from Compliance Plates form which had to be filled out and submitted with the other import papers etc.
Ours was a fresh import and had never registered before, but we were advised that even if it had been previously registered in another state, we would still have been required to undergo a full inspection.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
