Hey there, finally got around to getting my little R32 Gts-t dynoed today but was a bit disappointed with the result. Here's whats done to it
Intercooler
Blitz Electronic DBC
Apexi Airpod
3" Turbo back Exhaust
High flow cat
Stock ECU
98Octane fuel
Was running 14 PSI on the EBC but according to the dyno the maximum it reached was 11. The guy seemed to think that the stock ECU might be preventing it from boosting any higher but i thought you guys might know if that were true or not, or whether I should be looking at something else. He also said the boost could possibly be leaking somewhere.
Anyway here's the dyno graph, sorry about the quality it was taken with a webcam. Max RWKW is 121.4, but I was expecting 140+ Is there any indication on the graph of something terribly wrong?
Edited by Lithius
Whats with the dip at about 100k's? Big missfire?
If the dyno is saying you are running 11psi then i reckon your gauge is probably reading a bit high, My blitz dsbc reads very high.
Everything else looks good. Swap your plugs for a set of bcpr6es, wind in a bit more boost, set your base timing to about 16btdc and try it again.
In the meantime, do a compression test (while you are swapping the plugs).
Your current setup is good for about 160rwkw on 13-14psi if your engine is healthy.
doesn't seem right... I just had mine dyno'd and I got 138.8kw with a pretty stock car.. only have a FMIC , pod and 3inch exhaust, its running at 12psi. It originally ran 120kw.. on first run... second run pulled a higher figure..
I'd say the timing is out a little bit, thats where you would expect to gain power. 2 or 3 degrees out will mean big power losses
Looks like a bit of a miss at ~100, maybe swap or gap down your plugs
Other than that, as always, dyno's are best used for before and after, to see gains/losses
Should have dyno'd it before doing all your mods
What sort of condition is your clutch in? Not slipping is it?
Brand new Extreme heavy duty clutch, old one shit itself not long after it was imported. Just found out my boost controller is in % not PSI... so i've been running 14% which explains the difference in boost between it and the dyno. I still think 120 is low for 11PSI though.
So i might try changing the sparkplugs, winding up the boost a bit more etc. What's involved in changing the timing and a compression test? Any idea of a rough price?
Edited by Lithius
Shootout mode will give you a result that 'should' be comparable to other dyno runs in shootout mode
Wouldnt waste your time with a comp. test, as long as its not blowing smoke
Timing is adjusted via the crank angle sensor, on the exhaust side of your engine (if looking at it front on)
The Crank angle sensor that round thing with 3 screws holding it to your timing belt cover
This needs to be adjusted with a timing light
To put a new set of plugs in and adjust the timing shouldn't cost more than $100, the plugs you can DIY if you are hand with a spanner
I think it was done in shootout mode, it's hard to read 'cause of my shoddy camera work but down the bottom it says "Results plotted using dyno dynamics shootout mode"
Thanks for the advice guys, i will get some new plugs into her and look into getting the timing altered. will report back with any news.
It's not blowing any smoke.
Edited by Lithius
If you've got the plugs out, do a comp test. It's worth the time to do it and you will know that your engine is relatively healthy. Checking the health of your engine is never a waste of time.
new copper plugs will cost under 30 bucks. Get the timing checked on the dyno and adjusted at the same time if it's out, if it costs an extra 20 bucks over a regular power run i'd be surprised. Same for playing with the boost.
Hey I was just playing around with it then, trying to dial in 13-14PSI on my boost controller and checking it with both my boost gauge and the boost controllers boost metre, and it's now getting up about 13PSI, but is not holding it. Even tho i'm still revving higher the boost starts to drop (it dropped to about 8PSI before I stopped revving)
Does this indicate a boost leak or something else?
my r32 peaks at 12psi, but drops to 9psi by the time i get to 5000rpm. i was told theres a restriction in my intake path (most likely intercooler) but now that ive got a fmic, it still does it. i dont know what the problem is. but youre not alone! :P
although, my car made 145kw with cat back, pod and standard intercooler, so in my opinion something sounds a bit out for your car :P
s.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
