Just got my standard ecu remapped/dynotuned (rom tune from hyperdrive). Came up with 232hp at the wheels. DYNO GRAPH http://i13.photobucket.com/albums/a251/aut...ot/scan0003.jpg
My car is an 93 auto gtst with
gcg stage 2 R33 hiflow turbo (500hp)
full 3inch exhaust no cat and no spliter in the dump XFORCE system with 2 a midmuffler and rear cannon
apexi pod filter
gtr injector and z32 afm 040 fuel pump
front mount intercooler.
22$ boost controller still using the rb20 actuator with it presprung a little bit.
Does this sounds like a fairly decent power figure for an auto? i thought it was pritty low but yeah guy that did the tune seems to think its about all you will get from it.
ALso sometimes before it changes gears it goes on the limiter and take a while to change is this cause the auto can't keep up. Was thinking about getting a shift kit to fix this but dono if it would
Only problems i can think of that could cause lack of HP are:
I had to rotate the turbo housing cause BHDAVE had a himount manfold or something. Could the seal be leaking since i have done this and cause any problems. I doubt it cause air fuel ratios were good hyperdrive said and seems to hold boost fairly well. Also had a small crack in cooler piping but i patched it up with silcon hosing and put like 4 hose clamps on it (bit of over kill) but i don't htink its leaking
or
As someone mentioned the intake pipe is collapsing inwards with so much boost
Guy i brought the turbo off was running 12psi,with the stock injectors in it at this stage which is why the a/f ratio starts climbing at 6k and made 173rkw's http://image-cache.skylinesaustralia.com/f...-1132642989.jpg
Edited by AntonRx7
  • Replies 101
well i think thats what, 175rwkw?
thats pretty reasonable for the RB20... if my mind isnt leading me astray with the kw conversion
A good ECU is going to make a difference also thats for sure
it has gtr injectors
yeah it does feel faster actually runs nice. think maybe ill get shift kit as well to help out with shifting speed.
I just though only running 14psi for most the time is pritt shit.
It was done at hyperdrive in WA
it has a rom tune which is like putting a chip into it as its an auto so aftermarket is pritty hard to use
RB25 hiflow
i brought it of BHDAVE from this forum do you think maybe something could be wrong?
i am using a boost controller from the forums one of the 22$ ones, although the boost line seems to be normal i have been told so this must be ok. Just really thought i would have got more HP than i have
Edited by AntonRx7
yeah even though mines auto seems a bit odd doesn't it
could it be a boost leak from anywhere like the turbo or something i wouldn't have though so but i dono what else could be the reason. I am running more boost and on a hiflow turbo and you have more than me a bit odd. Wat dyno was yours on
you have an extra .5 of a litre but even then somethings is not right ay. Inlet temps were 50 i think it says on the dyno sheet to dono if that owuld make that much difference either
Looks like he's got not timing in there at all. Then again could just be a mushbox as well. Was the trans slipping?
can i point out that its a bit hard to call how laggy a turbo is without seeing the tune ?
Your assuming that all other factors are perfect.
if your timing is way out(cam belt slipped) for example it can be a pig to spool and make no power.
how would i know if my timing is not right. surley they would have told me if the timing was not right. I dono if the trans was slipping i would have thought they would have told me that too.
Did feel a bit quicker last nite as it was cooler but still dissapointed with the hiflow turbo
you got a continuous 170rwkw over 5500-7500rpm without it tapering off.. thats not bad to me from an auto RB20.. but you'd expect maybe another 10% I'd agree at least.
I have a feeling your wastegate is bleeding off boost after 17psi due to the spring not being strong enough.. afterall - its 10psi above (rb25 actuator?) the standard boost the wastegate is set for?
You'd really have to speak to somebody who has the same turbo on an RB20 and find out what boost they have to run to get xxx rwkw to get another base comparison.
Edited by predator2
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
