  • Replies 183
A little under $6k got me:
STRIP & CLEAN 6 CYL TWIN CAM ENGINE
BORE & HONE 6 CYL ENGINE WITH TORQUE PLATE
MILL 6 CYL BLOCK
CHECK SIZE & POLISH 6 CYL CRANK
SUPPLY AND FIT SCREW IN OIL GALLERY PLUGS TO NISSAN L/RB/CA/SR CRANKSHAFT
CLOSE AND GRIND CONROD
PIN FIT ROD
SHOT PEEN CONROD SET
BALANCE 6 CYL ENGINE
FULL HEAD SERVICE
FULL GASKET SET- NISSAN RB25DET
COMETIC MLS HEAD GASKET
WISECO FORGED PISTON W/- RINGS
ARP ROD BOLT SET- RB30
CONROD BEARING SET- NISSAN RB30
MAIN BEARING SET- RB30
GATES RACING TIMING BELT
TIMING BELT TENSIONER
BLUEPRINT ASSEMBLE 6 CYL DOHC LONG ENGINE
SUPPLY MACHINE & FIT OIL PUMP DRIVE COLLAR- RB25/RB26
I supplied the cams and paid to transport the engine to and fro which wasn't much considering.
knore,
not that you are asking me but... When I had my motor built up it was sat on a pallet, strapped down and glad wrapped up.
Fork came along and dropped it on my trailer that had a nice thick rug on it so I was able to slide the pallet off.
Myself and my other half then slide the pallet off the trailer on to the ground using a few bits of wood.
Easy Peazy.
One of the SAU NSW club members helped me out with TNT to transport it.
Best to get your engine builder to book it on their account and then bill you, that way you get proper trade price.
I drove to an industrial area (not far for me) and looked around for a pallet of the right size (you want one about half or even less the normal size). It was easy, had plenty to choose from. Companies just stack them up near their rubbish bins.
I bought a twin pack of those snatch straps for about $10 and strapped the engine down tight.
Ok thanks, so you pulled engine out yourself, put it on a pallet, strapped it down and then got TNT to pick it up and deliver to proengines.
Then when it was done proengines got tnt to pick up and deliver back to you?
  • 10 months later...
It is about my rebuild but it was also supposed to be a repository for NEO info which it has turned out to be.
Shonen - you're obsessed with highmount. I'm more likely to put nos on it than a highmount. That said, a 2835ProS would be nice but I can't afford anything atm.
I've already got the highflow so I'm sticking with that due to $$. I've got some cams going in though so that should make some difference.
I think the 4 doors have the viscous LSD and the 2 doors get the helical LSD which means I'll be up for a new diff at some stage.
I was pretty sure all the turbo (2dr and 4dr) have the helical diff and only the autos have the viscous LSD's? Does anyone know this for sure?
Pete,
* The internal diameter of the stock GTT guage holes is 60mm
* Defi BF guages (amber or white dial) are only available in 60mm
Therefore the Defi BF (60mm) gauges will fit fine as you can see from the pics, but the bezel will be mounted outside the hole.
This pic shows Defi black 60mm gauges (not BF) fitted.
Not enough gauges here.... :ninja:
JustinP; you want ideas on how to install a e-01 in the R34? We've done two now (one on my one and one for a customer) and we concluded that there is only one spot for it... and that's in front of the centre vents.
Custom bracket needed to be made...
Yep any ideas would be great :)
I was thinking of removing the ashtray, bolting in a bracket inside, and mounting it as low as possible there. I figure it will cover some of the double DIN stereo but don't mind. Think this would be possible? My gf said she would rather if I didn't cover the vents heheh
I don't actually have the E-01 yet so I haven't got a real idea on the size of unit yet, I guess I should check the specs on it.
Well the way I've done it is actually just using an upside down L bracket which "hooks" onto the air vents...
1) It's removable for security
2) It looks neat
3) You don't have to look all over the place whilst driving
4) The rather intrusive wiring can be run into the vents
5) Ventilation keeps the unit "cool"
6) Keeps double din area completely clear
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
