  • Replies 157
Posted Images
bah, thrash the shit out of it. ive been to a few track days over the past ~4 years ive had the car and not a thing has broken yet. I try to stay out as long as possible (brakes pending) which can amount to 30-45mins on the short track, stuff all on the long track :rofl:
skylines are fairly robust cars. unless you got a dudd :)
ill be out there all night!
Shaun
The only thing I am worried about really is my clutch now....and anything else that may choose to break between now and after the track day :rofl:
Once you're rolling it should not be too stressful on your clutch
Unless your looking to be tail happy round some of those bends but I hear thats out anyway :P
Hey talking about Brakes does anybody have some stockyes they want $50 for laying around? My fronts are warped a little and cannot be skimmed.
Edited by 7yphon
This is an incomplete list of vehicles that are attending:
1. 95 Toyota Supra TT manual
2. JZA70 Toyota Supra
3. Ford XR6T
4. Subaru WRX
5. Nissan Skyline R32 GTR
6. Suzuki Swift GTi
7. Nissan Skyline R32 GTR
8. Mitsubishi Lancer EVO 9
9. Nissan 180 SX
10. Ford Falcon GT-P II
11. 1976 Holden Torana Coupe
12. Nissan Pulsar GTiR
13. Subaru WRX
14. Nissan Skyline R32 GTR
15. Nissan Skyline R33 GTR
16. Nissan Skyline R33 GTR
17. Nissan Skyline R33 GT (Non Turbo)
18. Mitsubishi Lancer Evo 8
19. Subaru WRX STi
3. Ford XR6T
4. Subaru WRX
6. Suzuki Swift GTi
9. Nissan 180 SX
13. Subaru WRX
19. Subaru WRX STi
20. Nissan Skyline V35 GT350
Will be bringing a mate down for a look.
Would love to have a run but I don't think FJ20e powered 180B Wagon with Standard brakes can handle it.
Considering I've had total Brake Fad on two Cruises now. The rear disc brake conversion won't be done in time ;)
Edited by DNSV1600
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
