Group Buy: Cb Radios (updated - Dec 23)
  • Replies 255
Hey mate, mine turned up today. Thanks heaps! :(
you dont have the link for the car charger do you? or the sellers name? thanks
EDIT dont worry mate, found it: http://stores.ebay.com.au/Domiclo-AU hope thats the same one.
yeah thats the one if anyone needs them...im gonna get me a car charger too
my joint... this week im working til 9pm (so after 9 if ya want)... friday however im working til 330pm... anytime after that providing im home :P
just ring me before hand to see where i am... or set up a time on the weekend either at my joint or the factory
yeah, readin up on that you cant use the car charger to power the cb radio :blink: meh, you gotta use the same plug for the charger as for the VOX so yeh... the batteries shouldnt go flat in a hurry anyway.
Well done Ni. Very pleased with mine and currently trying to intercept some conversations around the bayside area. For some reason not many residents seem to be using CB's :D
Thanks for organising it and see you sometime soon mate :D
haha no worries.
yeah it depends what channel and what time... during the day early in the afternoon theres a lot of bumpkin babble :P
ive still got ABuSDs at home... and urs jax... and fernis i will post urs out today so u should get it wednesday latest
For some reason not many residents seem to be using CB's :)
The reason would be that you've got about a 500 metre line of sight transmission range with a handheld.
There's an extremely good chance that even if you can hear people, they won't be able to hear you, because the majority of UHF users have a minimum 3+ watt output, which means that unless you are using a repeater, you'll probably only be able to talk to people on the same block as you.
I don't like your chances of being able to hit a repeater with a handheld either, unless you're standing right under it!
25+ watts and a beam will squash you every time. :)
ive picked up people in Bendigo and Frankston chatting on mine. No bastard can hear me tho :P the supermarket where i work, the managers use cbs to talk to each other... havent had a chance to see if i can pick em up...
Thanks for the information. :P It was supposed to be sarcastic though but a bit difficult to convey :P I have used them out in the country a fair bit when on dirt bikes which is where this will come in handy as well as the cruises. B)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
