  • Replies 80
agreed with the silver 33 gtr that was one sexy beast :P
Have to say the corvette sounded nice!
Was also very pleased to see the silver 33 GTR from HPI a while ago. It's almost the perfect looking car for mine. Love the leather seats.
https://www.sau.com.au/forums/topic/95977-dyno-day/page/4/#findComment-1799174
well, i was happy enough with 174.8 rwkw, let alone 272 with an exhaust leak!!! :D
however, im only running a fmic, an exhaust with a std cat and stock boost!!! me thinks there is some un-tapped potential there......
Edited by Frink
https://www.sau.com.au/forums/topic/95977-dyno-day/page/4/#findComment-1800525
Not sure.. I *think* it's the engine originally in the Trueno. The engine it's replaced with in D is from the AE111 and that's the one that revs to 11k. Either way, my bro is clueless about the whole thing, just like Takumi hahahahaha
https://www.sau.com.au/forums/topic/95977-dyno-day/page/4/#findComment-1801914
What i can remember:
96 R33 GTS-T S2 with 3" exhaust from dump = 151kW
91 Corolla Seca SX, stock = 75kW
Pro Engines work ute - 137.3rwKw!
Googies - 272kw
Frink - 174.8 rwkw
The litle datto 1600 -180sumtin kw
Corvette - 275kw
Mine - 290kw
Other grey gtr was 260somthing i think??
But thats all i can rember/pull from this thread..
https://www.sau.com.au/forums/topic/95977-dyno-day/page/4/#findComment-1806002
i want one...
Formula Atlantic Facts.
1.6-liter, four-cylinder, non-turbocharged, 16-valve, fuel-injected, dual-overhead cam, Toyota 4A-GE engines, capable of producing 240 horsepower at 9,500 rpm and speeds in excess of 165 mph
The teams run a 12 race season on a minimum of $650,000usd
http://www.toyotaatlantic.com/Atlantic101/FastFacts.asp - interesting read
https://www.sau.com.au/forums/topic/95977-dyno-day/page/4/#findComment-1806042
Thanks for remembering my power figure geordie.....
I was impressed when mine made 186.7rwkw running standard boost :D
AND, my power FC is sitting in my bedroom waiting till very early next year to go in and then ill guarantee over 200 at the wheels...
Hows that for an R31??? :)
https://www.sau.com.au/forums/topic/95977-dyno-day/page/4/#findComment-1812813
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
