R32 - 2 door vs 4 door
35 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
ok here's the thing.
i've already made a few decisions on what car i want to get.
here they are:
1. nissan
2. skyline
3. R32
4. manual turbo.
5. 2 or 4 door? <_<
i'm not gonna use the car for drift or track but it's going to be used as a daily driver.
get me to uni everyday, work,etc..... and also an at the lights drag every now and then.
:P:P B)
now i've never driven these cars before so is there any difference at all other than the two extra doors?
thanks.
your opinions are much appreciated
https://www.sau.com.au/forums/topic/96249-r32-2-door-vs-4-door/
personally i'm a 2 door man... ive got a 2 door 32 that i use as a daily driver and i couldnt be happier with it,
theres not too much difference performance-wise between the two, the 4 door being a tiny bit heavier i think.
the main differences are cosmetic, are u intending this car to be a people mover (all ur mates) as well as the way to get to and from work/uni? if so then maybe the 4 door is more practical.
the rear lights are the major reason why im not a big fan of 4 door 32s, i prefer the 2 door rear lights.
hope this helps a bit
I quite like the 4 doors, but it might be a little harder to get a manual. Before i got my R33 (2 door) i was close to buying a R32 GTS4 4 door just cos they're a little different and also having driven and been in a 4 door R33 theres a hell of alot more room inside. the whole cabin feels less claustrophobic, and the advantages of getting passengers in and out are also pretty convenient. In any case im sure you'll be happy... unless the time arises where u need to use the back seat for some lovin' then you'll wish u got the 4 door :wink:
I have owned both a 2 door and a 4 door (current)
I prefer my 4 door over the 2 door i used to have.
It looks tougher for some reason. (and is heaps faster:)
There is no difference in interior room in the 32's though ( they share the same wheel base) . all the extra doors do is make it easier to get in and out of the back seat.
Four doors all the way. Overall shape looks a lot more cleaner IMO. No sharp inclines off the the rear window like the 2 doors. I think the four doors look sporty, especially ones with the factory aero kit. Like mine :P
Me biased? Never....
Edited by Baz
Go the 4 Dr ive had mine 6 months now, and sure they look a lil plain stock but coilovers give it a tought stance will and make a hole difference, its all the same shit really performance wise, but i dont have to worry about my mates draggin in and out of the 2 door,
the 2 and 4 doors have the same wheel base, therefore same drive train. slightly more room in the back but still not really much room at all. 4 door has a bigger boot. personally go the 2 door after its a sports car not a people mover.
WOOOW! im felling good :O B)
I just got a 4 door. I wanted a 4dr for a while, not many around. It may have rear doors but the leg room in the back is stuff all when a 6ft3 person is driving.
Yep something about it. Put a mild kit on one and the front catches up to the tough rear.
4 door all the way man there the best and if you have noticed a foor door is about as fat as a gtr at the back so bolt on wide front gards and your laughing ill get photos of mine up soon you will see that they are f-ing rad
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
