Howdy, just wondering about peoples opinions on this dyno chart. Are the a/f ratios too lean??
its an R32/rb20det/goodies:
(HKS 2530/gtrpump/sard 550cc inj/microtech/cams/camgears/3"full zorst/etc)
Thing is, it was tuned at place "x" and place "y" said its too lean to drive at full throttle. PI$$ed off because i have spent money already tuning, and i shouldnt have to spend more!
what does your injector duty show on full load (near where it leans out on the dyno?) if its normal ie: not near 100% then it could be fuel rail / fuel regulator being the bottleneck in your fuel system
not sure, "x" should be able to tell you. it sounds like you need a higher pressure regulator to have more fuel in the fuel line. sounds like on wot throttle the injectors aren't maxing out but the fuel line can't maintain enough pressure and keep it full of fuel so it leans out, at least thats how my understanding of the fuel pressure regulator is? someone else should be able to confirm. im pretty sure you can get higher rated nimo ones which are a direct fit
From what my tuner has said to me it might be ok, does it ping up high?
Ive been told that you have to really put the fuel in on the torque curve cause thats the most likely time pinning will occur then you can lean it off a bit up high. Im not sure if its to lean but just talk with your tuner some more about it.
it doesnt ping at all. yer the tuner said they could remap it for $660 from scratch, including cold start etc, but they didnt speak very highly of microtechs, and basically convinced me to try and get hold of a power fc and Z32 afm... so i might just leave it for a couple of months til i can find one, then go from there....
Is the original harness there? Paulr33 - microtechs dont and will probably never use an afm. It looks to me as though there might not be enough DC the first thing I would try is to increase the injector pulsewidth. The standard FPR will do the job fine. If it is still leaning out chances are its the pump. At 60% DC your using about 2.2l/min of fuel. For around 220rwkw you would want at least 3l/min at 3bar.
Have you had the car on 'y's dyno?
It may be that 'x's o2 sensor requires calibration and is a little out, hence reading lean when it is actually rich.
Before you do anything I would throw it on a different dyno for a power run to see if their dyno also shows its too lean.
Personally I don't think it has fuel pressure or flow problem. It goes richer at around 170 kph. If it had a fuel pressure regulator or fuel pump problem it would continue to get leaner. It looks to me like it has been deliberately tuned that way.
As others have posted, go back to the original tuner and talk to him about it. Tell him the readings and your concerns and give him the chance to respond.
:) cheers ;)
its not that a power fc would fix the problem, i think the microtech just needs a remap, its just that the microtech is pretty inferior to the power fc in ways of fuel economy.... its what you need nowadays.
i guess i could go back to place "x" but i am generally unhappy with the result of 200kw @ 17psi, poor economy, & bad cold start tuning. This is the reason for getting place "y" to have a look at the car, give it a run on the dyno and tell me their thoughts.
all well, thanks for the responses ppl, ill let time figure out what im gonna do... its gonna sit in the shed over the silly season anyway, there are cops everywhere this time of year!
it seems black is the new white, and imports are the new copbait
hey mate where are u from? can u PM me the name of the dodgy tuner if u r in Perth, cause ive had a few issues too with lean AFR's.
cheers
Brad
Where was that tuned?
I'm sure Shaun @ Boostworx would get the Microtech running sweet, he knows them backwards, look at Freebaggins R33, 300+rwkw out of that, with a Microtech
Looks very lean too me, might pay even to take it somewhere else and do a run and see what AFR's it has on another dyno, could be the calibration of the O2 sensor is a bit of?
Looks like its running some decent timing, making 200+rwkw, so if i was detonating, Im sure you'd know about it
i know it sounds gay but im not gonna say where it was simply because Adelaide is too small... i dont know anyone on here, and i dont know who could potentially have a read. A lot of the time people will generalise from one persons bad experience and then the chinese whispers start....
but yer, i have heard that Shaun @ boostworx is good and reasonably priced. It may pay to just get the microtech tuned! still havent heard of testimonys of good experiences with microtech on something that isnt a rotary.... ooooo i said rotary....stoopid lawn mowers
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
