I'm heading out there for Test N' Tune on 14th December to give my car a run before the end of the year.
If anybody else is keen on coming, can meet up there or before-hand to say hello. I'll be coming from the Goldcoast
You've got a couple of weeks notice so no excuses >_<
https://www.sau.com.au/forums/topic/96713-willobank-141205-test-n-tune/
  • Replies 87
ahh.. a low 13 or so to start with hopefully.. nothing massive. Depends how many kw its pushing after I get it tuned next week. Its an RB20, with highflow rb25 turbo and some support mods. Needs more than an SAFC to do anything too great i have a feeling :D
Will bump it up a few days before to see if anybody is interested in meeting up on the night so if you're running the R can come say hello :)
ill be out there.
hopefully i can better my woeful time of 14.9 i posted last nite :P
P.S Who owns that superchared v8 skyline on sau? caus he was out there last nite too, was runnin consistant low 11's
ill be out there.
hopefully i can better my woeful time of 14.9 i posted last nite  :huh:
ROFL! that would be Johnny (NAR33).
ran [email protected]... fully siikness spec
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
