Did you call it 4 Square or Downball?
73 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Back in the days of your primary school / high school / secondary collage did you refer the game as Downball or 4 Square? The game I am talking of was played with generally 4 players (but not limited to) and the playes were given titles of King, Queen, Jack and Dunce. The object of the game was to hit a tennis ball and to get the other players "out".
What did you call it? To me it was known as Downball, others believe 4 square
https://www.sau.com.au/forums/topic/96894-downball-or-4-square/
  • Replies 43
I'm with the Snowcone!! Downball is against the wall you MONKEHS!!!
4 square is the one with the King, Queen (which led later on to a social complex), Jack and Dunce.
As Bec also stated, this carried on until it was some ridiculous number like 16 where you ended up having to lob the ball over everyone's head to make it fun.
Loved the backhanded shot to fool the person behind you.
SAU 4 Square and Downball Championship series!!!
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
