Hey guys, is anyone here a fan of low cars
I just lowered the line and goddamn that thing is low now.
Didnt really know what to expect, just jacked it up and changed the springs. dropped it again and hmmm LOWRYDA!!
donna have to get those as plates. lol or BOUNCIN cos thazz the other thing it does now.
Anyways just looking for any opinions on lowness. anyone else got a lowered line but not with coilovers (coilovers hmpff why do it properly when you can just dump it) and would like to share with me their driving experiences in terms of handling etc.
And please no links to the whiteline website. lol
latas
RiaZ
Hey Adrian I will try to call you about the "view the dump & front pipe session" at EVO R
https://www.sau.com.au/forums/topic/9705-low/
  • Replies 60
Mine has Apexi coilovers which where far too low when I bought it. It used to scrape the tyres in the arches, and scrape exhaust bits on dips in the road. I lifted it 25mm, and it still below legal, but because I have stock body it rarely scrapes now. Except in my own driveway which has a big slope and a lump at the top. That 25mm didn't make a huge difference in handling, and its still set firm, but then I don't know how a stocker handles.
Might want to have the wheel camber checked, or make friends with tyre retailers :)
https://www.sau.com.au/forums/topic/9705-low/#findComment-147900
I have KYB Coilovers lowered below legal limit.. I must have the hardest suspension on earth!!
I have stock Type-M front bar, and it scrapes on just about everything. the middle of the exhaust scrapes on speed humps at most shopping centres. the rear muffler (it's angled) is FAR too low to reverse upto a kerb efficiently.. bah!
but all in all, the car handles like a dream.... looks dam schmick. So i'm happy.
https://www.sau.com.au/forums/topic/9705-low/#findComment-148028
When you lower em too low , and my front is right on that limit, then the front lower control arms actually invert and hang lower at the inner pivot than the outer mount on the hub.
This creates a rocking effect on patchy road surfaces and also most shock bodies have no upward travel left which means on reasonable bumps the stops are getting hammered.
Hence this is why you get the occassional crash over a bump.
Having said that , a line lowered till the sills on the floor is a sweet look.
As b2barker said , if lowered the camber goes to neg and on the rear it is hard to get it off as there is insufficient
adjustment.Inside tyre wear then becomes an issue.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-148073
100mm clearance off the ground is the legal limit,
but from the wheel centre to the mid of the wheel arch needs to be lime 320mm in the front and 330mm in the back.
mine is not near there.
hang on.....
just measured it roughly
front is like 300mm and rear is like 285mm
hehe
looks slammed. if i could just get some 18's
https://www.sau.com.au/forums/topic/9705-low/#findComment-149828
Cant roll a coke under mine.
My tyres hit wheels arches too - but as for making friend friends with tyre retailers i havent had a prob with tyres they have been 90% tread since ive had it in Aug. I would be more grovelling to the likes of pedders! The rubber bit that stops it hitting the wheel arch on mine has warn away and the shockies have packed up (i think that was the basic explanation) so they wanted to put new springs in it which will lift my front end a little but the ansewer to that was NO! so now i gotta get special shockies - i think - suspension isnt really my area of expertise i kinda say its making my CD player skip fix it but i dont want it any higher - like the difficult female i am. Oh and be prepared for lots of scrapes thats why i didnt want to take on mandurah in the next run because that place just is shocking for low cars i cant even get on grannys driveway cos the curb is too high.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151648
reading back about what GTRken said about the stops getting hammered and the bouncy castle effect thats whats happened to mine - i think the stops are pretty much non existant now. But theres apparently a solution without making it any higher that will last for ages and if it doesnt my mechanic will be seeing what the inside of my boot is like!! Just dont play the CD player on bumpy roads and advoid country driving because you'll be itching to get out of it by the end.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151655
Nizmo , what type of shocks are on the car.
If they are the usual Tein , Hks etc , they are designed for smooth racetrack style roads.
They have HUGE spring rates and the shock valving is usually so stiff it doesn't need the springs.
A few of us go to Wilkinson Suspension in Bayswater. He sells quality gear ( Bilstein, Koni , whiteline , superpro etc ) and can get you good shocks and springs that actually go up and down.
Cheers
( no I'm not on commission )
Ken
ps luv your signature hehe ...close the door.:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-151694
Originally posted by Pva_Glue
also a condition known as "TItt Giggler" :P
It's been also reported to male genders... due to Man Boob effect
cheers
Joe
I think you mean Jiggler , joe .
Or do you mean joe Diggler ??
Cheers
( cracks me up , bwahaha )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151698
all sounds very expensive!! im the kinda person that likes to take my car to one place and have them handle it - too many cooks spoil the broth as i found out with my Z31. Ive been told estimate $500 to have it fixed - should last as long as i have car - sounds decent to me. I would rather spend the money on something that actually makes it go faster!!
https://www.sau.com.au/forums/topic/9705-low/#findComment-151861
$500 to repair the shocks, supply new springs and bump rubbers sounds pretty cheap.
I think Wilko does Koni and king springs for about $1100-1200 but at least you know they will work.
Trust me , decent suspension will make your car go faster , around corners and even on the ( heaven forbid ) dragstrip.
Cheers
(ndf )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151904
Oh and in reply to taking it to one place, nobody is an expert on everything ( not even phptf ) but if you know which specialists to take it to a better result will occur.
For instance I wouldn't take my car to Wilkinsons to get tuned but visavis I wouldn't take it to Exhaust dynamics for a w/alignment.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151908
Hey Ken,
I resemble that remark. I always take my car to the best man/woman for the job. I too have super stiff suspension, and will be taking it to Wilkinson Suspension to let them have a look at it and recommend a handling package for racing.
Nizmo,
$500 will not get you very far when it comes to good suspension, I would shop around and check out what each are offering first.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152028
your right joe , that is an odd question.
Funny thing is , coming from you , it sounds perfectly normal:D
Answer is no, you would have to take the springs out and replace them with solid blocks and fill the tyres full of concrete cos they have a cushioning effect as well.
Cheers
( we get some weird ones )
Ken:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152325
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
