  • Replies 155
Posted Images
Hey, i got the VHT stuff, only cuz i spent about a week trying to track down a supplier of duplicolour metalcast (only to walk into a local supercheap to find out they had it after i already brought the vht stuff)
http://www.vhtpaint.com/anodized.html
the blue anodized + the silver under coat
got mine from autobarn caboolture
Hey, got my R33 GTS afew days ago, doing all little mods to it to make it look good in my eyes. Really wanting to do this DIY but the calipers are much different, guessing because its a GTS
Spraying these wouldn't look so good imo. Would it be practical to upgrade the calipers both for performance upgrade and for looks? + anyone know what rims they are?
Silly me, After making my initial post Donkeys ago, I forgot to show off the finished Project, Btw thanks again paul for a great Tutorial. worked a treat, also gave me a chance to fix up some other things i found wrong. I went with the Metal Cast Blue cause it is just awsome. Also I used Vaseline on the Nissan logo, before the paint, then just scraped the paint off with a Razor blade after painting.
  • 5 months later...
good thread!
i'll be doing mine in 'dupicolor metalcast red' as most agree that this is the best paint for the job.
i will also give it a base coat silver to help bring out the red BUT im not sure if i get the top clear coat...is this needed?
lastly, will this paint ever crack/peel if i track the car?
i didnt bother with the top coat, the finish of the anodized paint was enough for me
as for the cracking/peeling on the track - not sure on that, they say its rated up at 500 F (approx 260 C) intermittently, so how hot do your brakes get???
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
