you going for an internal gate or an external ?
I think the Plazmaman one might fit the 34s.....as it uses the standard runners.
Just need to find out of the runners are the same on 34s are they are for 33s.
Internal gate, HKS GT2835 Pro-S. Should tun nicely on the RB25 and be responsive enough to use on the track :D
Yeah I've seen the plenum kits sold by unique autosports.. but they are more expensive at $1500 than the GReddy ones! Plus they use the existing runners whereas the Greddy replaces the whole lot. For $1500 i could think of better things to spend it on.
  • Replies 54
Internal gate, HKS GT2835 Pro-S. Should tun nicely on the RB25 and be responsive enough to use on the track :)
Yeah thats the turbo Ive had my eye on for awhile....but im now weighing up the costs on getting the R version and getting a manifold and wastegate to suit.
HKS do kits for R32/33/34 2WD but can't find details of turbine housing ARR .
Nengun I think are advertising kits for RB's but won't let me in with Yahoo E mail .
The HKS USA site shows an SR20DET doing 300.6 TQ and Hp at the treads which sounds about the go . Yeah I know another SR 2L ally 4 .
Im outa here guys the trouble n strife and th tin lids are out and home brew awaits !
Chow for now , A .
I think your tuner liked my turbo :D
I'd expect on a stock RB25 it wouldn't make full mumbo till at least 5k-5500rpm. Set of cams and cam timing may help to bring it up a bit quicker. Mine made 1 bar 4000-4500rpm on a built 26.
My tuner said he would be able to get one to start boosting as low as 3500rpm.
yeah, start making boost @ 3500... meaning 1psi.
You couldnt see anthing moderate 15psi+ till around the 5000rpm mark, give or take a couple rpm
Making boost and actually going somewhere are two different things.
You'll also be limited by the higher comp of the NEO
  • 3 weeks later...
the larger the cams, the later the boost comes on but will give better flow (and power) once boost does come up.
If you want boost to come on earlier, try the smallest turbing AR that is available, port the head, and get the best flowing exhaust you can find - but definately not larger cams.
Sorry guys, but going back to the injector discussion on page 2, would GTR injectors be a good option for the 250-270rwkw range? They are top feed so they should fit sreight into the NEO correct? I have similar power goals in mind (270rwkw max) and was wondering if GTR injectors are a viable option for my power goal, as they flow 440cc. They can be bought for around $350 here in NZ, MUCH cheaper than the big name brands.
I'm also in the game for a turbo upgrade this year... only thing holding me back now is a reliable and relatively cost-effective ECU option for the auto transmission :rofl:
Once that is sorted then I guess the GT-RS is a good option (or at least something similiar).
GCG Hi-Flow option seems to get a good wrap around here as well...
Hi Guys
I also have a R34 NEO, great thread on the turbo upgrade which I hope to do it in the near future. Need the $$$ first, working on the exterior mods atm. Btw, do we have to change the CPU as well if upgraded turbo?
Yes I can see that :lol: that's a mighty fine looking GT-R badge you have there... nice GTT though :blink:
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
