Friend said she dragged Mr. XXX and XXX was granny shifting or what ever crap that is and she won etc etc blah lbah..... Since I have no interest in dragging anyone nor have I tried, is there a difference in the way you shift gears when you are dragging? Basically, I just wanna know how mnay ways you can shift.
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/
  • Replies 40
hahahahahah okay well this girl you know has watched the fast and the furious to many times hahah
number 1 - Never take lessons from the fast and the furious
number 2 - Never take lessons from the fast and the furious!
Number 3 - Repeat steps one and two.
but anyhow double clutching is a form of shifting thats used on cars that have no syncros, seeings though all modern cars have syncros, double clutching is not necessary.
Sometimes double clutching is good whilst shifting down, to get into a gear. Youll Find that in some cases when a car is cold shifting down into 2nd can be hard therefore the use of double clutching is used to help it get into gear.
The term "granny shifting" is just used to insult someone on how they change gears.
In terms of dragging, I can gaurantee that none of the professional fellas (or anyone who knows how to drive) double clutch. Double clutching takes time, time is precious over a 1/4 mile.
get it?
Shifting normal - clutch-change gear-release clutch
Double Clutching - Clutch in - put into nuetral/blip throttle/disengage clutch - Clutch in - change into gear - clutch out.
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/#findComment-1769771
or if you have a dog box i believe you can flat shift... ie dont use the clutch and jam it straight in
umm flat shifting is not shifting like that infact shifting like that is a bad idea and doesnt really work in a racing sense
flat shifting = keeping the go pedal on the floor while changing gear giving that short time to raise revs whilst changing
the reason this is usually only done with dog boxes and such is cause its VERY mean to the box i.e. standard box just breaks and cries :D and you dont want that
it is even bad for the engine in worst case scenarios (if you miss the gear, engine revs up and boom! nice little shower of what used to be engine internals)
and as for shifting in a drag it is basically finding the best for your car
Example: Skyline GTR(with standard box) a medium speed shift is the best because syncros in box cant handle full rev fast changes (reason why standard boxes always have stoofed syncros)
also rev limiter changes arent always the best either (again with GTR) if your setup is making peak power at say 6500rpm then the key is to keep the revs around that number too high not making as much power as you could (power curve drops off) too low takes too long to get onto best power
*end rant*
if i have unanswered anything tell me and ill have a go
RellikZephyr
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/#findComment-1769842
From what i understand, Flat shifting is basically as u guys said above, shifting while holding the throttle wide open.
Ive been told and believe that is it bad for pretty well any gearbox because it shock-loads the gears on the main shaft against the gears on the cluster shaft because as the clutch is let out, it smacks the input shaft gears against the other gears at the gearbox tries to catch up with the amount of revs the engine is doing. Instead of having them at a reletivly constant speed as u do when u letter the throttle off as u change gears.
Im not 100% sure if thats correct or even makes sence. so correct me if need be.
Edited by Viper1555
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/#findComment-1769903
haha in my old rwd mazda 626 i used to not only keep the pedal to the metal... but also not use the clutch... just jam it as hard inot the next gear as i could hahah... allthough when i missed it really sent a jolt back through my arm ahaha
spose thats how you expect to treat a car worth $slab of beer
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/#findComment-1770118
Guest Mashrock
yeah similar story in the pajero.. i beleive it will b reak soon. but its all this rain and wet weather making me drive crazy as its the only way it will break traction.
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/#findComment-1770169
Totally agree with what RellikZephyr said.
If you got a really old car without synchros, GET ONE!
If you got a dogbox, SLAM IT and SLAM IT HARD while keeping the foot planted throught the firewall!
Basically, in regards to the shift itself, as fast as you can without breaking the box. On average between clutching, changing gear and engaging the clutch again will take bout .5-.7 of a second. A straight cut shift will take between .4 and .6 depending on how hard you do it and in drag racing, that's a fair bit of time after 3 changes.
https://www.sau.com.au/forums/topic/97552-how-do-you-shift/#findComment-1772026
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
