  • Replies 71
Posted Images
I know there is
2 x blue 4 door
1 x black 4 door
1 x platinum silver 4 door
1 x athletic silver 4 door
3 x silver 2 door (not sure which silver)
2 x yellow 2 door
2 x red 2 door
1 x black 2 door
1 x white 2 door
2 x bayside blue 2 door
2 x black gtr
1 bayside blue gtr
Edited by mxtcy
I think Trev from FBI's R34GTR is bayside blue also.
I test drove a red R34GTT at Valley View 3 years ago (before I bought PCOTY) and it was an absolute bucket of crap. Had been smashed several times and felt like a car that had done 200,000km - not 50,000km as claimed.
I saw a white 4 door R34GTT on North East Rd near my place a couple of weeks ago, with an older guy driving it. Had trader plates on it.
good to hear you are joining the fold Chapman :D
sky30 - I think Damians (= user Cell on SAU) R34 is originally midnight purple from the factory - very rare GTT colour, but it is a factory colour I believe. I assume this is the one your mate bought, as I haven't seen another in SA.
So that makes it about
1 x white 4 door (soon to be 2 in Jan)
2 x blue 4 door
1 x black 4 door
3 x yellow 2 door
2 x red 2 door
2 x black 2 door
1 x white 2 door
1 x purple 2 door
2 x black gtr
2 X bayside blue gtr
Andrew: Nope purple is the 33 gtr colour the guy in Japan sprayed it after it was purchaced. As that purple was not avalible on GT-T's at all. The rare colours of GT-T's are Yellow and Pearl white (there are two whites) for the 2 door, and Pearl white, and Metalic silvers on 4 doors. I only know coz i got a new front bar sprayed and did some research into the paints.
Edited by mxtcy
good to hear you are joining the fold Chapman :(
I thought tat colour was only avaliable on R33 GTR, think he told my mate a dude in melbourne got it sprayed that colour, Damian got it from him.
Didn't know about the Black GTR but funnily enough saw the yellow one this morning!!!!
yeah im prety sure theres an old dude with a grey beard from flaggys, with that
black gtr.. he must be 50, wat a legend!
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
