Ok ive been thinking about this conversion for a little while and would like some input/info on what exactly is needed and what needs to be modified to make it fit ?
Some of the questions I have are.
1. Can I use an PFC from a GTR ?
2. If yes for 1. then will it be pretty much plug and play or would there be a lot of mucking around with wiring looms etc ?
3. Heard that the sump needs to be modified to make the engine fit
is this true ?
4. IS the RB26 heavier than the RB25 ? Was told by one person that because of the extra weight it will stuff up the balance of the car. Said it will be quick in a straight line but no good on a circuit..
5. What needs to be moved or relocated...im guess the battery may need to be relocated to the boot.
Thats all I can think of for now......
thanks in advance.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/
Thanks adam...I wasnt aware that Driver was doing the conversion.
R31. Just with the general trend of things I just thought there would have been a lot of differences between the 33 and 34 to justify a new thread. This has been the case with most parts I tried to get for my car.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778724
I'd say not really. Im putting a 26 into the 31 and its pretty similar to anyone else's using a later model 32/33
With 26 you'd be getting the whole loom aswell (i hope you are) then its just a matter of buying GTR upgrade bits like PFC and stuff, nice and easy :)
Everyone doing a RWD conversion needs to modify the sump.
ie. remove the GTR diff and weld the hole
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778747
Cool thanks for that nismoid....
but one thing I would like to know is.....is it possible to do this conversion with in a few months ?
Almost all people I have heard of doing an RB26 conversion have taken a year or longer....I cant afford to have my car off the road for so long.
Also I have not seen anyone make any remarks about the weight balance aspects of this conversion and how it affects the car out on the circuit.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778760
Theres nothing to stop you from doing the conversion in a day, if you've got all the nessicary parts, labour, and knowledge. All comes down to good planning...
In terms of weight I'd imagine a RB26 would be marginally heavier than a RB25, due to the extra turbo and associated bits hanging off the side.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778761
And it took me a while to do because i just didnt have the time to do it..
It is very possbile to do in a couple of months.. its mostly time consuming
The wiring is the hardest part.
The engine is a direct fit using gt-t engine mounts - gearbox etc fits up fine
You will need custom cooler piping as well as exhaust as you will now have 2 turbos
Thats all i can think of at the moment.
EDIT:
And for those who want to try and make it 4wd you cant as chassi is different and you cant fit the 4wd box.
Edited by Driver
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778835
Spot on. We were gonna have mine done in 2 weekends till we found it had spat a wheel rear turb wheel... added to that JMS must have stored the motor outside for 11ty billion years as ive never seen such a rust covered motor <_<
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778899
EDIT:
Thanks for that Driver....
Like I said before I have heard that the wiring is a nightmare but is there any sort of wiring diagram available or is it all just guess work ?
and hehe I dont plan to make it a 4WD....I dont need a computer to help me drive.....hhaha well thats my excuse until I can afford an R34 GTR. :lol:
also about the sump....if it needs to be chopped...is that alright for the RB26 motors ?? I heard they need good oil supply especially out on the track and people actually put extended sumps on them...
or am I missing something here ? :D
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1779304
for the 26 into the 31... its not a "large" job. Wiring is the only main thing. And i need to take to my tunnel with a sledge it seems... cant wait for that part.
other than that, bit of piping mods and stuff. 1k for your old motor out, new one in.
Then maybe $1500 to get all the other fiddle stuff like loom changing/wiring etc. I think 2.5k sounds reasonable for labour costs for a conversion. 3k tops
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1779314
Could you fit an aftermarket RB25 sump onto an RB26, or do things just not line up?
People always need to baffle the RB26' OEM sump to avoid oil starvation anyway, so rather than arsing about with the OEM sump when you can just stick a nice baffled, finned and possibly winged sump instead?
Edited by scathing
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1779532
You have to use the RB26 sump, not an RB25 one.
Thier construction is dfferent.
Just get a fabricator who is expirienced @ welding etc to chop the diff off and weld the hole up basically
y do u HAVE too? i know the rb26 one is much much stronger/rigid, but the rb25 one fits with no mods at all and bolts on like stock (different bolt holes though and its like a sheet of tin :blink: )
saves cost of fabrication work if ya on the cheap :) worked on my rb26 in 2wd no problems, and plenty of other do it that way.
cheers
Brad
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1780118
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
