put your money back in your pocket with the high flow cat, it is as they say an oxymoron. Mine is not a high flow and I saved a few $$ I only replaced my stock one cause it was knackered and I broke the flange bolts off it doing the gearbox/clutch reinstall.
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-151358
What did people pay for their front pipe + dump pipe ?
The only price ive been able to get so far (confirmed it will fit on my R33 GTS-T) is $350 + $350 for a 'mines copy' from www.japanesemotorsport.com.au
That seems alittle pricey for me. It would be atleast $800 just for it all up Ouch!
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-151388
Custom Exhausts is in Ozzy Park. They installed my extractors on my old car and made an absolutely stunning stainless mandrel system on my mates integra. Was a few years back though, i presume theyre under the same management.
Or you could go Speedworks in Carbon Ct. But theyre quite busy at the moment and might not have the time for custom exhaust jobs.
If you wanna go the whole hog and get the dump pipe as well, id go for something japanese. I priced a HKS one up the other day that was only $75 more expensive than i was quote for a local custom job.
Remember, 70 yen to the dollar is your friend :P
Red17
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-151570
how loud are these screamer pipes anyways,
or does it make the whole exhaust roar alot more,
anyone with any enlightenment
i really should be getting back to exhaust dynamics soon to get mine done. he seemed cheap and definately knew what he was talking about
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-151846
I have the Cat back and front pipe on my car, i'm looking for a dump pipe in the near future..
I'm still with standard cat also.
I've heard that not having a high-flow cat can limit the amount of boost you can run with a bleed valve??
ie. My mate got a turbosmart boost controller on his 180, and they said he needed a high-flo cat to get a full 12psi, as it's peaking at 12, then dropping to 10psi ?
Any truth in this ?
Could explain why my "home-made" jobbie that gave troy 10psi, isn't working on my car (still at 7psi)
-Kym.
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-152499
I'm getting my high flow cat and 3" dump pipe done at MagicTune in Cannington. $520 for both, stainless steel, mandrel bends. I got a quote from a guy next door to Extreme machines, which was $500. He said he would do one pipe instead of two. I'm getting way out of my depth here, all too technical, but I went with the first quote because they are closer to home.
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-153307
the guy next to extreme machines is wayne(willeton exhausts)
and i cannot tell you how much this guy knows
because theres too mcuh too tell lol
i never knew bout him till i checked out extreme machines and they were hell praising him so i thought i would go and check him out and now i realise why they praised him so much coz he does a absolute ripper of a job,he is the one who replaced my piping from the cat to back of muffler to straight 3"! i'm goin back there soon to get my twin dump pipe and high flow cat done, might ask if he can make me a cat-out pipe ;) so anyways yeah i just thought i would let ya know i recommend him 100% adrian :(
https://www.sau.com.au/forums/topic/9802-front-pipe-cat/#findComment-153340
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
