  • Replies 54
haha went to drags last night.
got busted.
the cops were good guys tho, no fine no abuse
i was quite happy with the outcome
but damn they just had to come out of nowhere
oh well it was only a small meet up anyway
but man its scary
got busted.
Hmmm..what do you expect to happen? It will happen sooner or later. The cops are getting pretty cluey about this sort of thing.. and no doubt they check these boards for signs of it too. Take the warning, as it sounds like they were being very generous - if you keep doing it they'll get pissed and drill you.
INASNT:
YUP...HE BOUGHT HIS CARS EVERYWHERE
AND ARES SUPPORTS HIM
SO HE GOT ARES SPEED NO.S PLATES
DID U SEE THE BLACK SOARER ON THIS WEEKS AUTO SALON? THATS ARE54....BUT THAT IS SUPPOSE TO BE HIS PLATE
COZ HE SWAPPED HIS ARE53 WITH THAT GUY
*HE IS A GOOD FRIEND OF MINE*
got busted.
but man its scary
were were the drags last night?
pm incase there r cop spys here! :D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
