  • Replies 49
Posted Images
Yeah i went there yesterday and the air is like ice.When he was testing the temp from the vents it was measuring 4dc to max of 5.5dc.Pretty cold.
He also said to give him an hour and a half but he was only an hour.What he did was change the filter,seals and regas.
Hey steve he looks like a relative of yours.I could see a bit of facial resembelance.:lol:
Yeah - its that cold you wont be using full fan with ac on, i cant handle 100% fan and ac at 18 now. Ice is a good way to describe it!
..........no relation :mellow:
  • 3 weeks later...
I had the A/C in my R32 GTR looked at on tuesday by a local mob. They hooked up the gas rig to re-gas it and told me all the pressures and everything was perfect. They regassed it anyway (for free) and their was no difference and then told me it was because my FMIC was blocking airflow to the A/C compressor.
Anyone else had this problem or do I just need to visit a better workshop (ie the mob in this Groupbuy) ?
Edit: Well Phil just told me more about my A/C problems on the phone in 5mins then 3 local workshops did in 3hrs (my last tuesday afternoon) so i'm booked in tomorrow to get some work done :P
Edited by benm
I am going to call phil 2moz.
I have this problem when i turn the air con on.It makes a loud gassing sound about every 5 mins just cruising which in turn dips the power for a second.It could just be the compressor tho.
And lately it has made an even weirder sound.And i think it is air con related.
I will post up how it all turns out.
Rock on SAU BBQ!!!
hey N1GTR - can he rebuild compressors?
I need new bearings, and maybe get the clutch done at the same time. If i send him mine could he rebuild it and send it back to me here in Adelaide?
Could you ring and ask him prices etc for me? (save me an interstate call :))
Cheers ;)
I would ring him for you but am flat out this week - when you say rebuild the compressor wouldnt it be cheaper and easier to buy one off a half cut?
Well I visited Phil this arvo and he certainly knows what he is on about. Took a whole 5mins to diagnose my problem (leaking hose) so he just regassed it to get me by until I can get the car back to him for an entire to have it fixed/serviced.
When I arrived the AC was set to 18.0c but was actually blowing 27c air and when I left it was blowing 5.1c air, friggin freezing :huh: (but its leaking so its quickly getting warmer again).
Bl4cK32 - Phil can rebuild the compressors, I asked him today for you. He said to definitely give him a call so that he can grab some more details.
As above, id ring him for you next week if you want, but i would be wasting his time seeing as i dont have the part in front of me and couldnt answer his questions on the unit
He is a good guy, and knows his stuff, im sure if he can help you he will
Hi SAU members!!
does anyone knows a part number for R32 GTST A/C compressor? and if you know other alternative compressor that fits R32.
my A/C been a pain in the b**t! first Outside temp sensor was out and I fixed it.
second, gas was out so I regased it and now, compressor won't kick in and keep blowing fuses.
any help will be great!!
Cheers!!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
