Hi guys i have just bought my first Skyline and i am wondering what mod to buy next to increase my cars BHP.My cars is sitting at arround 300BHP @0.9 psi.It has a cat back HKS super dragger exhaust,GTR cams,in car boost,boost gauge,HKS induction kit,blitz dump vaule and a full GTR body kit with 18s.I am not sure if i should buy an upgraded head gasket so i can use more boost or buy a bigger turbo.Can someone pls help? Thanks
https://www.sau.com.au/forums/topic/98802-my-first-skyline/
And what sort of intercooler is it running? 0.9psi? you mean 0.9 bar, or 9psi? GTR camshafts or cam gears? I forgot the conversion for BHP, but what sort of power do you want to end up with?
As a rule of thumb, 12psi is relatively "safe" for boost, but expect a lesser life-span of the turbo. (personally I wouldn't push it past 10psi)
It sounds like an aftermarket ECU might be one of the next steps, along with a tune. Once the basic mods have been done, as you have already, tuning the AFR's can give a reasonable amount of extra grunt.
If you're looking for BIG gains, then perhaps an uprated turbo swapout, along with fuel-pump, regulator and injectors... but you'd still need to have the aftermarket ECU fitted to tune it all.
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1798989
impact blue! =-o
"There's a party in my pants and you're invited"
"Instead of changing up to 3rd, I pulled the handbrake on, and didn't realise what I was doing "
"It is 12.38am on Wednesday 23 November 2005. I am lying, nekid, on my bed. "
"Then I had a laser hair removal appointment for the… erm… nether regions."
Your site is a dirty read! =-D
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1799179
bhp is pretty much the same figuire as HP. with 300HP you probably have a larger turbo. If your dont have a front mounted cooler then someone lied to you about its power because there is no way it would be 300HP with a stock cooler or stock turbo.
btw. Nice wheels, got me a set :P
Edited by krzysiu
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1799196
impact blue! =-o
I'm a bit baffled at what that has to do with this guy wanting to increase his car's HP
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1799222
i doubt it would make that much power by the sound of it. u r runnin stock turbo right without a FMIC?? as someone said, even running 9 psi will reduce your lifespan of the turbo without a good cooling system. so maybe get yourself a FMIC?? since ur runnin a cat back exhaust system, maybe get a high-flow cat and a high-flow dump pipe?? get these basic things done b4 u go crazy. just my opnion any way.
Edited by frankxy
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1799354
A front mount intercooler would be a worthy upgrade, 0.9 bar is about the efficient sort of boost a R33 with a standard turbo should run, consider some sort of engine management, possibly a piggy back computer (ie. SAFC-II) or a complete stand alone (ie. PowerFC, Microtec etc.) to margine for more power if your aiming for in the future.
350bhp @ the wheels is probably a desirable figure and sensible figure to target for one stock internals on lower boost otherwise expect costly engine rebuilds in the near future.
Btw I have never heard of an RB25 powered car that could make 300bhp on a stock turbo and especially impossible if a FMIC is not present. Unless your running something stupid like NOS or methanol injection :P
My 2 cents
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1799534
Paul!? "the street with the xmas lights" Paul? or "SR20DET" Paul?
It's been pretty good man! Few things here and there, but i'm enjoying the ride =-]
From what I quickly researched, brake horses and HP are pretty much the same thing, but kw to hp is always 2/3rds. So this guy has about 220kw, whether it's at the fly or wheels, we don't know. Interesting to see it put your way though, and I guess that's probably about right for the powerloss in most cars. Unless we start talking auto's.
https://www.sau.com.au/forums/topic/98802-my-first-skyline/#findComment-1799595
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
