you want this puppy, which is sold at all Jaycar shops around australia. You do have to assemble it yourself though.
http://www.jaycar.com.au/productView.asp?ID=KC5349
Catalog ID KC5349, $9 each.
You then have to buy whatever colour LED's you want (which they also sell) and assemble it, or get a mate to do it for you if you don't have soldering skills. It comes with instructions, and you can get bright white LED's to go on em pretty cheap.
And this is what you want for the interior light...
I got a blue one of those from Raybrig for the interior... also got these bwadbwoys for taillights/indicators/pacecar flashers:
Rezz, where did you get those LED brake lights from? I need to know if they have the blade type brake lights as my Skyline uses them instead of the normal ones.
But I want a set of those ones you posted also as I have courtesy lights on my 4 door and they would be perfect!
totally interested in group buy. I also want to replace the bulbs in my driving lights (standard s2 type)...oh oh, and my high beam cause i've done a 4 headlight conversion so my lowbeams stay on with my highbeam and now my HID's make my high beam look shit...
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
