Hey everyone,
Basically interested in importing an R34 GTR RB26 engine from Japan.
I've already got an FOB price on it in yen, was wondering if i'd have to pay any customs/duty on its arrival?
Also, I assume there's a way to keep these taxes at a minimum? :D
I'm probably going to buy it this week sometime as i need it in a hurry!
Thanks.
Edited by IOWNU
https://www.sau.com.au/forums/topic/99723-importing-an-engine-from-japan/
Hey everyone,
Thanks.
Hey, how ur doing? Im just new to this club and can u plz tell me how to create a new poll or a new quote or just basically a new forum chat?
Thanks
That is SOOOOO Off topic but anyways...
Select a forum, then click on the newtopic option to make a new thread. Once you're making the new thread, you can add a poll, pretty straight forward.
Looks like you've worked out how to quote.
yes you will have to pay import duty, and GST on it, and the cost of freight.
so engine cost + FOB charge + freight. call that cost A
cost A + %10 (duty) = cost B
cost B + %10 (GST) = landed cost
add to this the cost of having a customs agent handle the customs clearance and payment of taxes. the charge (at a guess) would be around $50-$100.
There is no legal way to minimise the tax, they will need a proper invoice and may even request the wire transfer receipt.
Beer baron is correct but you dont pay import duty on the freight cost from the jap docks to here , you only pay import duty on the jap land freight cost but you pay gst on the lot .
Just like he said no legal way to reduce the tax and if you do cheat and get cought you may loose the goods and be charged with criminal a offence , not worth it to save a few $ .
Ali, Can I ask how you went about finding the engine? And if you have, how you organised/organising freight?
Hey mate,
My Uncle lives in Japan so I often get cars etc.
Firstly i purchased the engine for about 260,000 YEN FOB. That was an R34 RB26 engine with 68,000 kms on it......bargain if you ask me.
First time getting an engine so not sure as to the freight procedure yet...hopefully find out today or tommorow.
I'll update this thread when I have further info.
Peace.
Ali
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
