whats the deal with bugs and my car? ...
i have a white gts and every time i come back to it after leaving it for a while its covered with flying and crawling bug things, dirty or clean....
is it the colour? because it doesnt happen with my mums white corolla or white magna...
i think the bugs have good taste never the less...
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/
Exact same problem... car is coated with little flying bugs; my car is white as well, but I find that it happens after a car wash. I blame the soap/water that they use - I think it's got a sugar base or something along those lines that make the finish attractive towards bugs :P
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1820872
i had the same problem. little flying ants were eating my car!
when i did my quarterly bug spraying for my house i gave my car a really light spray of the stuff. i left it for a few mins then went and washed my car.
its worked so far.
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1821186
does anyone know how to get bird and bat crap off the car ?? i was it using a hose and soap but in the sun it looks to have caked itself in the paint :( i got a black r33, would a wax or polish help ??
Try using Meguiars ScratchX
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1821804
scratchx only fills in scratches in the clearcoat.
if its a oxidised stain or dried poop (ie has eaten through your clear due to the chemicals and heat) then you'll need to cut and polish it. if its deeper than that then you'll need a new clear.
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1822223
maybe is a white-paint/import thing. i used to have a white silvia, and everytime i washed it, all these little flying bugs would all start crawling over the roof & bonnet. never happend on any of my parents cars (both locally delivered nissans)
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1822707
my car has dead bugs with blood on it and i cant wash off
i will eat them
bacardi is my friend
YOU ARE GOING TO EAT TEH DEAD BUGS AND BLOOD?
Does will know you kiss him with a mouth like that??
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1823470
go to repco or supercheap and get something called "bug and tar remover"
spray some of that sucker on, let it soak for a few mins and it'll come off.
it gets the black soot that stains on the rear bar from the exaust off too.
https://www.sau.com.au/forums/topic/99936-bugs-love-my-car/#findComment-1823497
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
