i wish i was as rich as you :P  :)
i have a erm, major prollem. Major overheating, coolant pissing out everywhere (went underneath to take a peak, looked like it was even coming from the bellhousing of the box, which is bloody wierd, must be trickling down from somewhere else), couldn't see any busted hoses or nething *shrugs* :D
my bet is you have a leaking heater hose. most likely it's leaking underneath then dripping down onto the bellhousing.
  • Replies 118
hate to sound like an egotistical prick
but can someone bring a video camera
i cant find my f**king charger
and as this is possibly the last time my 4door will be running, i wouldnt mind catching some runs but inparticular a burnout on tape
i can supply dv tape
cheers, mark
Hasnt been any rain/drizzle here (Penrith) in over an hour now and the roads are starting to dry up whilst still very overcast (temp is 18c with very light breeze).
According to BOM it hasn't rained at all in the Horsley Park / Eastern Creek area and is also 18c so provided the rain stays away it could be a very good night of racing.
you should be a weather man!
A few reports...
* White R32 GTR (I assume BENM?) into the 14s (so far :()
* TWO06L seen coming back along the return pass with a lot of white smoke coming out
That's only off a couple of mates that are there.. clean up duty at the moment, there was a big accident with a 150mph Micks Motorsport GSR getting crossed up, hitting the other car, and slamming into the wall at 3/4 track!! :O
Ugh what a shocking night :( :(
* Bad gear selection problems on all 5 runs
* Ben can't drive
* New rear muffler is super restrictive so I had no top end and low boost
* Ben can't drive
* Paul decides their aren't enough clouds in the sky so makes his own
* Ben can't drive
* Mark has a damaged gearbox
Ah well I still did a new PB's for everything (R/time, 60ft, TS, ET) so I guess I got what I set out to do. I'll be out there again sometime over the next month hoping for a massive improvement.
was sooo there tonight!!!!!!!!!!!! MISSED THE CRASH!!!!!!!!!!!!!!!!!! no fair :(
hate being at wsid and not running! but was pit crew for DHC.. so i got to go into the main area where the cars do burnouts for their runs.. sooo mad :( managed to see twoogle blow that oil seal! so sad!!
forgot to take my camersa!! such an edddiooottt :( more pics peeps!
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
