Stock Turbo Psi
Ryuk
 Share
Hi, having just recently getting a wc34 Stagea, ironing out a few bugs and installing a manual boost controller etc. I am curious as to what you guys think is a safe level to run the stock turbo? I had heard no higher than 12psi and currently running just shy of 10.
Where did you hear that info?
Why do you doubtimg it?
Are you new to the internet?
Your not the first to raise the boost on a stock turbo.
You'll find that the stock ECU starts to struggle long before the turbo itself is in danger (it will run to 14psi plus....probably....)
The stagea ECU is very conservative and will quickly run very rich and reduce the timing; you will notice this as more boost not making it go faster....and lots of black smoke.
So....if you want to run more than about 12psi you are going to have to do something electronic anyway (eg new computer or SAFC or fuel cut defender)
Here's 2 graphs from my car in the old days.....red line is stock (top line is power, dotted line is boost). black line is after installing a fuel cut defender.
This graph shows why the power goes down like crazy; the stock computer was dumping in heaps of fuel (running rich) to protect the engine from what it assumed was an issue....see dotted red line which is the air/fuel ratio on the stock computer.
  • Like 1
Where did you hear that info? Your Mum.
Why do you doubtimg it? Your Mum talks some shit.
Are you new to the internet? No, unfortunately I'm not. I do however see as to how you may have been confused regarding my prowess. Given I joined a topical forum, located the relevant Stagea discussion pages and I tried to make a general inquiry about said stagea like a tots newb. lol ;) #twat
Your not the first to raise the boost on a stock turbo. & I wouldn't be the first in given ya Mum some pounds per square inch either. (Tip: that's like a quite a lot, more than 3 bars even).
Thanks mate for your helpful response, I noticed that the modest increase I gave it didn't necessarily equal the expected returns. Can see why this may be the case now.
I like the way you say you aren't new to the net but failed a quote edit.
Anyway, as Duncan kindly provided, and you figured out, just raising the boost on a stock ecu really isn't goiin to provide fantastic results.. As has been mentioned numerous times before.
So....if you want to run more than about 12 psi you are going to have to do something electronic anyway (eg new computer or SAFC or fuel cut defender)
Had another look at your graphs and finding it a little odd that the fuel seems to drop so drastically (pre FCD) on basically the comparatively stock perimeters. While the Blue line is displaying a more even and greater power curve the two PSIs remain pretty equal. I would have assumed that at around normal performance the ECU/Injectors should be able to maintain load?
While I am not noticing any black smoke running at 10 psi, you mentioned that this may be because of the ecu retarding the timing & loading extra fuel, leading to injector failure. Wouldn't this extra fuel mean that it would be capable of simply providing the extra requirement? or is that the injectors are not able to maintain that load and essentially fail?
Is there any short term benefit to insure the exhaust flow is in turn increased, dump-Cat-mani-exhaust etc? Otherwise it appears that a ECU tune is really the best option.
The injectors won't fail.
Its the ecu adding too much fuel. Which is fixed by tuning it, if its a series 2. If you have a series one you have less options available.
Yep that's exactly the point....the stock stagea ECU is very conservative and does not like extra boost. FCD was a cheap and dirty fix, something like an SAFC would be a better idea for a car that is going to stay reasonably standard. Whole ECU replacement is a couple of grand no matter how you go about it.
Just nistune it. As standard, it goes very rich outside stock parameters and the timing is very conservative, especially in the midrange rpm.
Be warned that installing an ECU on your car is like opening pandoras box.
 Share
    • Came across these Ganador reps and am wondering if anyone has used these/come across these ?  Seem to look like reasonably good replicas (shape wise) from what I can see. Ive been told by them that they are moulded to be exact copies of original Ganadors (but thats what every replica version will say) https://www.shiftperformance.com.au/ganador-style-mirrors-suits-nissan-skyline-r33-gtr Photos of them installed appreciated Thanks 👍
    • lol, yeah, and how gutted I am now I’m back over in Europe (actual Europe) and dealing with the nightmare of U.K.-Continental Europe bureaucracy.   Anyway, arrived in NL early January with the BMW, whilst the Skyline followed suit about a week later. Both cars ended up stuck with their relative importers for about six weeks. Since then, I made a trip to the Nurburgring with a friend and have since ditched the Skyline in the garage. This week, I finally managed to find a suitable shop to do an alignment so hopped on over to Germany to fix the miserable mess the local Netherlands shop conducted; the car was just not aggressive enough in the rear for my driving style - I found myself understeering a fair bit at the ring which was really a first for me with this car. Mis-matched F&R tyres can be held partly responsible - have now moved to F+R NS2Rs. One thing I’ve noticed is the 180kph limiter just does not cut it here. I quickly hit that (for the first time) in Germany on the autobahn. Japanese circuits are small - at least the ones that were near me. I rarely spent much time in 4th. After much deliberation with the HKS SLD, I have ordered Nistune from Matt. Whilst the Skyline has been gathering dust I got to learning the highly neglected BMW I bought in the U.K. was in fact just that, highly neglected. Took the ol’ dog down to Switzerland last weekend with a progressively deteriorating front end. It went from vibration during braking at highway speed on the way down, to vibrating non-stop on the way back. I’ve already fixed numerous engine issues - low oil pressure, f**ked injectors, incorrect coils and plugs, electric water pump. Still to do is a suspension and brake overhaul, rear subframe replacement and likely more ageing engine electrical components. But I must say, I love it. After so long with the Skyline, I really didn’t know cars could be so comfortable.
    • Thanks. I adjusted my soft cut to 7600rpm and if I see I'm still making power there, I'll consider readjusting to possibly 7800rpm while on the dyno.
    • Yeah not sure. I sourced another relay no problem, its definitely a relay according to Nissan parts, they used those specific relays on a bunch if cars around that time, but my two options are, find a behind dash wiring loom which is proving difficult, or get the current loom fixed up by the shop when they put my rebuilt engine back in, they are confident in their auto electrical abilities. Thing is my current loom has anti-theft stuff and GPS immobilisers wired into it so easiest option may be to just fix the current one to save ripping apart the immobiliser.
    • Took it apart to get to the bearing found out i was wrong the bearing was pressed on to the diff side and the part i removed only had the bearing side, checked the bearing all looked fine took the shaft end to a shop and they recon it was movement from back and forth that made the marks and not rumbling about, so i just changed the seal and put it all back again.
