First you use the search button :)
You will find this feature very useful for alot of questions about your car.
In the past month there has been a plethora of threads opened about r33's and oil changes and what oil to use, some I think even include pictures.
Most use Motul Turbolight 10W40 or similar, and the oil filter is a Z145A (Ryco).
Nath
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1822804
The how to:
http://www.skylinesaustralia.com/forums/in...showtopic=10035
I used Motul 300V Chrono 10/40 - quite expensive but it held oil pressure much better than any other oil i've used before and the engine ran very quite and revved quite freely. The cheap Ryco filters are fine to use.
-rb25
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1826542
How do you say its fantastic.  Most oils are fine.  Dump it at 5000km and replace it.  Its only after years of running you will know if the oil is great or not.
Oil pressure on the stock gauge seems to be similar for most kinds of oil with my car..
It might be bs but i've noticed that different oils seem to lend different qualities to the motor - like make it run smoother and quieter, but thats just me...
Each to their own i guess, i would run a thinner oil if all i used the car for was round town work but my car gets heavy highway use and many hours stuck in peak traffic, so i wanted something that would give protection at the upper thermal range, and also with my car on 103,000km i doubt the clearances are what they used to be, so i opted for a thicker oil....in terms of protection you're right, i wont know for a while, but i do know that its working great sofar as nothing has broken yet :)
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1828554
Coz I just recently put Valoline 20w-50 XLD premium on my r33 gtst?
Arghhhhhhhhhh *Screams*
Please take the advice of the other guys and do not use cheap oil in your R33. It is worth every cent if you spend a little more each time you do an oil change.
Nath
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1829841
I reckon any semi synthetic that is from a reputable manufacturer will do the job. If you're religious with your 5000km service I wouldnt worry too much. If you extend it to 10000kms Id go full synthetic. I rather take the cheaper oil dump more often approach..probably in japan our cars were getting an oil change every 15-20k kms. 10k kms if by the book. As motors get older therre is more importance in doing the regular changes. It is all the unburnt hydrocarbons and petrol related products that get into the oil that cause further degradation of seals etc and decrease the effectiveness of the oil in lubricating.
Edited by benl1981
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1829854
I doubt any damage would be done by using thicker oil (20w-50w) but if youve got a newer engine you may as well take advantage of using higher quality thinner oils like 5-40 etc.
If youve got a bog stock rb30e with 200+ on the clock you wouldnt want to use anything other than 20-50 however due to the clearances rings etc being worn. Too thin oil will cause the motor to lose compression due to it slipping past the rings etc.
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1832330
Motul 4100 and a Ryco filter every 5,000km is all you need to know really :O
benm i will spank you if i catch you putitng turbolight in your new GTR. 4100 is a very cheap oil and is not a full synthetic oil. it is a blended oil. go at least for the 8100, but i would say use the Chrono 300V.
I've used the castrol forumla R 10W60 and personally i think it's too thick. a good full synthetic around the 10W40 area is what you want.
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1837837
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
