The auto is fine for the drags, but if your planning on giving it a heap of power then the manual is much better. You can think about putting in a stall-converter to help with launches, but the manual is much more fun to drive.
See'ya:burnout:
The auto is good. It is very weak tho'.
The thing will need a strong rebuild, a shift kit of some kind, a larger trans cooler perhaps and a hi-stall built.
Alternatively a trimatic like the VL turbo's run would be a much better bet for serious power. The performance rebuild of a trimatic or turbo350 is very cheap, even after the custom install its going to work out cheaper for a tough as nails trans.
The dude TRY9, i think it was him, had a trimatic fitted to his RB and was doing 10's with it from memory.
Auto i guess easier just for dump and go... no brainer generally.
If you do up your engine and you end up blowing an auto box you're going to require a whole new one or a rebuild (expensive). I was quoted once $1800 for a new auto fitted, and that was for an old R31 (guess same as VL box?). Hate to think how much for R33.
In a manual most of the time you just blow the clutch (much cheaper!), replace for a bigger one and keep driving.
I took an auto for a drive when i was looking around. wasn't very happy at all. It didn't pull all that hard. it was in good condition overall tho'.
With manuals you can stretch the gears out more too.
But yeah autos are way cool for drags spesh for consistent times.
HI Stall big turbo combinations work really well, say your turbo doesn't make boost until 3300rpm, by getting a 3500rpm HI Stall as soon as you put the foot down your at 3500rpm instantly and at boost. There is a down side to it though, wheel spin is quite vicious and fuel economy is down while cruising as the convertor is basically slipping until 3500rpm.
Every Auto has a stall converter but there usually set very low like 1500rpm, a HI stall convertor just replaces the stock one, and no it can't be switched off coz it's sort of like a clutch that won't fully engage until the set rpm.
The car won't always be at 3500rpm(eg) but at the slightest press of the accelerator the rpm's will jump up to 3500, that's why the fuel economy is effected.
An Auto is the way to go
Think about the developments in motor sports today, all of the big ($$) teams are using auto boxes with manual selection through paddles/buttons on the wheel. Whilst I would agree that a stock R33 auto isnt a quick shifting beast, with a little work it has great potential.
The idea that you can hold gears longer in a manual is crap. I can select a gear and keep it there until the Porer FC's rev limiter cuts in (not a nice feeling), but more importantly you can set the auto to shift at the correct rev point. (no more going over the top of your power curve, and costing you time) every time without you having to watch the tacho (which moves too bloody fast anyway :-P )
As mentioned above boost comes on when needed via the correct torque converter.
The other advantage is that the throtle is held open for the length of the run (no need for the blow off valve to work) and hence no spool down on the turbo. (ie boost from foot down to foot off)
As to the idea or poor durability my R33 puts out 180 RWKW and has given no problems. (stock auto) My new auto (sharper shifts, higher stall converter) was in a car that was constantly given stick and put out over 230 RWKW.
My advice is dont listen to those who have not played with auto equiped skylines. (they probably dont eat quiche just because they were told once that REAL MEN dont eat it)
  • 10 months later...
I must say I went from a vl auto to r33 manual and manual kicks ass. So much more involved, used to get bored when driving an auto. The manual is so much more active and involved, like a real race car
I think manual is great for dragging too, everyone loves the chips in 2nd and 3rd when u do a quick shift :D
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
