well since ive melted a hole in my rb20's no. 5 piston its obvious i need to rebuild it.
ive got a nice set of cp pistons to rebuild the motor with but im wondering what else i should do to the bottom end while i have it apart.
i plan on using arp head studs and an oringed block with stock hg to keep it from blowing out under high boost but what other things should i do while the engine is apart.
i was gonna have the rods resized as well as shotpeened, but got to thinking do i need to change out the rod bolts and the main studs?
the motor should be capable of nearly 500whp, and i want it to last a while so what are your guy's thoughts on making it do so.
i was also gonna toss on an n1 oil pump to help the oiling system as well as a proper oil cooler.
ideas?
https://www.sau.com.au/forums/topic/100320-uprating-rb-bottom-ends/
If you are going to stick with factory rev limiter, shotpeened rods are adiquate, but if you plan to rev the engine harder thin get a new set of rods. Replacing rods bolts is a must, get ARP rod bolts.
N1 oil pump and oil cooler is also highly recommended.
It goes without saying that you are getting the block x-rayed and crack tested, internals checked, ballanced and blue-printed.
yeah, block is going to be inspected and cleaned along with the crank and what not, going to have the crank's oil gallerys grubscrewed for proper cleaning......
as for revlimiter im proly going to keep it near the stock 7.8k rpm, perhaps raise it just to add a bit of head room but nothing more past 8.5 for sure.
the head will be cleaned and checked as well as well as uprated valve springs to cope with sustained high rpm operation.
what arp bolts can i use on the rods will z32 vg30 bolts work?
How about sussing out why you burnt a hole in the piston, or you may end up doing it again with a fresh motor...?
Id hate to think what the power band will be like on the 2Lt with just more up top....
Why not go for a 2.4Lt bottom end (rb26 crank and rods, and them toyota factory forged pistons) ?
Edited by Bl4cK32
More cubes via RB26 rods and crank is the only way you are going to make it possibly reliable.. It will need too many rev's and boost to make ~600hp at the fly with only 2ltrs and 7.8rpm.
Do the airflow calcs you will see what I mean.
500whp is 373rwkw... Good luck reaching and maintaining it if you stick with the 2ltr. ;)
Edited by Cubes
Carl wants 500rwhp... Thats around 600hp at the fly.
For any motor its going to need rods and pistons.
The larger motor will always last longer than the smaller and be more reliable as it won't need to spin as hard to make the same power.
hrmmm, you are right on a few fronts but i didnt say it was going to MAKE 500whp, i just wanted to beable to make one dyno pull and get a number like that......
the reason the piston went was due to a dodgy romtuned ecu, however decided that for high power needed to step it up so i invested in a pfc.
i do believe its possible to make 450whp as it was making nearly 400whp (387 to be exact) untuned and at moderate boost (17psi) made peak power at about 6.5k rpm iirc.
but back to the original question what arp bolts can i use on the bottom end?
RB30 bottem end is all thats needed.
- Luke
Maybe...but an RB30 is a bigger engine that sits higher in the engine bay...not major problems but problems all the same. Some may have problems with engine numbers/registration etc.
Plus, i love revs, and screaming out of 2nd gear corners with the thing just screaming its head off up to 8,200-8,400rpm. A std RB30 bottom end wont do that. Some will say wont need to, and thats fine, but i like how it does.
RB24 again would be good...but im more inclined to spend the money saved with using std RB20 crank and rods on headwork, valve springs, perhaps bigger valves and cams etc. Things that will actually help the engine make power.
Whilst i am always impressed with how Rb25s with bigger engine RB cars always get up and boogie so quickly, im a lazy street driver and i now like how my car isnt spooling up everywhere with lots of induction noise etc.
If my RB20 let go, id be curious to do fresh bearings, oil/water pumps etc. Crack test, balance...the usual. Then just throw in a set of 81/82mm pistons with 8.6-8.8:1 compression...and then spend the rest of my budget on headwork, cams etc.
And im still trying to get my head around how everyone says the torque makes the car easier to drive, when all i ever see is the engine with better low rpm/torque just frying tyres. With a little less response, and higher rpm power band it seems the tyres/suspension handle the power better at higher road speeds?!?!?!?!
With something like a HKS 3037 or some other nice 550-600hp turbo, i think i would quite enjoy the power band from 4,750rpm to 8,500rpm. I would hope it makes 320-330rwkws on about 1.4-1.5bar.
N1 oil pump ......... is also highly recommended.
I read this a lot, and personaly I think it's a big mistake to use a wide drive flange oil pump on a narrow drive flange crank. This is made even worse by the higher oil pressure relief spring the N1 pump has, because it means more torque loading on the narrow drive flanges. With the crank driving on less than half of flange on the oil pump, the tendancy to crack the rotor is exacerbated.
I see no reason to run an N1 oil pump anyway, they flow no more than a standard RB26 oil pump. All they do is relieve at a higher pressure.
;) cheers :D
;) cheers :D
fair enough SK, but i had planned on fitting a oil pump drive collar to the crank while it was out, it couldnt hurt any........
another reason for the n1 pump is for the slightly higher pressure, since the poor rb20 got stuffed with no oil cooler an external one is to be fitted to this new motor for longevity's sake.
roy - my gt30r is the same as a hks 3037, and belive me when she gets going it is an insane blast to drive, im anxious to see what she will do once i rebuild it with proper compression......
boostn32 - the l20 rod bolts were a proper fit? hrmmm i may have to look deeper into this.
Edited by carl h
Increasing cubes does increase power. I know going from the 3.0Lt std bore to the ~3.1Lt i have in my car roughly equals about 10 more Hp across the rev range....or so a reliable source tells me :P
I would have stuck with modding my rb20 had it not blown, and i know what you mean about revs there Roy. Having ridden a RZ250r for the last 6 years i love revs, and that thing is built for it (redlines at 12,000rpm :D)
But i like not having to downchange (as you noticed when i drove your car) when goin up a slight gradient. I like the fact i can leave it in 5th and cruise up a hill.....tyre frying just means you havent sorted suspension or tyres properly :)
You are a lazy man. I estimate 42 gearchanges in my car per 1000mtrs whereby burning approx 72 calories. That is extra sauce on my meat pie, and an extra beer with dinner base don the average number of kms travelled in a day.
As for 3.0L vs 2.0L no doubt, but as for 2,4L with the same head? Your 3.0l is also using a different head.
I have no idea what the answer is, but would be interesting to take your RB30 build budget, and spend all that money on headwork and cams. It will be interesting the performance difference of the two engines usign the same high flow turbo , even allowing for the differend head etc?????
...and for what its worth, the car doesnt have that nasty tune anymore, or the 10cm housing. When the 8cm housing went on with the new tune it transformed the car...LOL, that means it still sucks and is laggy, but at least i dont have to use 1st gear and a carrot on a stick and string to get the thing up a hill in 1st gear :D
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
