  • Replies 130
Yeah before i set my boost to 12 psi,i drove around with a fmic but with stock boost.I noticed there was a different in flow and my car drives smoother.(maybe its what type of cooler u choose,tube&fin or bar&plate).Not advisable to run more than 12 psi with the stock turbo.I think 12 psi is the optimum boost level for it anyway(correct me if im wrong).Hi flowing isnt a bad idea i guess?
13.6
-outlaw racing-
havent experienced spiking with turbosmart type 1
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-156406
Yeah I had this set-up but I also installed a boost controller. I found that with the standard boost setting there was more lag down low but better top end due to the larger FMIC.
Anyway, I set my boost to ard 11-12psi which was ok. I was told that the standard turbo can go to around 14psi but at that setting I had trouble with air/fuel ratio.
I think its better for your turbo if you have a custom dump and front pipe and better for your engine to have a safc or ems if you decide to consistently run higher boost (14psi) with standard turbo.
Just my two cents....
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-156520
Everyone has some lag, but whether you experience more due to a FMIC I don't know for sure, my car seems more responsive with it, and it definately produces more power. If lag has increased then it is not a significant amount, but I have quite a different setup than most, so I don't know how this has affected my results.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-157332
The No.1 problem with cooler selection is incorrect size. It amazes me a little that people consistantly get fmic that are sometimes over 200hp more flow than required. And I am amazed even more by mechanics and tuners who make this recomendation to customers when they would never do such a thing with camshaft selection,head porting or carby size.
Just pick your HP and 'then' pick the matching parts.
I don't think I've seen a GTST with a stock turbo yet with a properly sized fmic.
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-157556
rev,
Your right that most people have overly large intercoolers, but I for one don't wish to swap intercoolers everytime I do something to my engine. I have all my airflow side setup in anticipation of a larger turbo, therefore I currently have a larger FMIC than I currently need.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-157745
GTS-Vspec,
Not a problem. I assume you are already planing to get a turbo of the correct size for the intercooler.
This thread however is about the stock turbo. And many people are blissfully un-aware of the waste of money a larger intercooler can be if done the wrong way.
Look forward to seeing you rip it up with the GT30 on!
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-157778
I think anyone that fits a FMIC is planning on a turbo upgrade of some sort, whether it be hiflo'ing or a larger turbo, as once you've done the fmic there isnt much else that can increase the power of the car but increasing the turbo (after ecu, fuel system etc). But at the same time once you start to play with the boost you really need to get a better intercooler to control temperatures. No point in fitting something slightly bigger than the stock one just to suit the stock turbo.
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-158232
Rob upping the ic size and front location, is a good idea even on a stock turbo if you want that exra power or if your car is going to see sustained boost (like on the track).
The problem is that if I was to ask " how much HP does you intercooler flow?" Most wouldn't be able to tell me.
Then upgrading to a larger turbo, being good and all, will also mean the intercooler was not selected with a specific turbo in mind.
This kind of 'bolt on' mentality is the reason 80% of all the modifed street cars (including V8s and everything else) perform fairly ordinarily considering the amounts of money thrown at them.
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-158551
What results do you think I will attain with my trust unit then? Will I get slower 1/4 mile times? I can see how moving the side mounted intercooler to the front would assist with air-flow, but at the same time the stock cooler can only flow so much cooler air to the turbo and because of its small size can only cool the air slightly. A friend of mine with a 180sx mounted a GTR cooler into the front nose of his car and even with the limited flow (180sx's nose must suck for a front mount as hardly any of it is exposed at the front due to it dipping off) he noticed the car running considerably better and actually found boost to come on quicker. Before the fmic he was running 14.1's with it he ran a 13.6 I think, no other adjustments. Anyway with the fmic and lower tyre pressures I hope to be biting at rev's heels :(
https://www.sau.com.au/forums/topic/10034-fmic-stock-turbo/#findComment-158555
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
