I've had a FMIC fitted in the last few weeks and since i did, ive been having trouble with very low rev drops, and sometimes stalling. its mainly when i put it into neutral coming up to intersections, or just with the clutch in coming up to my drive way. Ive searched a heap of possible causes for it but my car ran perfect before this and it seems like too much of a coincidence to me. Any suggestions??
https://www.sau.com.au/forums/topic/100384-stalling-after-intercooler-install/
i dont think ive been blowing smoke. i did actually notice yesterday that the 1st rubber hose coming off the cooler on the passenger side had a bubble in between the metal fasteners were the pipes would meet. this might be the problem.i could have a leak there. i'll play around after work tmoz and get back with the results.
on idle what are ur revs? i had to tweak with the idle on my plenum coz my revs were to low
On idle it is fine. it doesnt hunt at all, and sits on about 700RPM roughly. its only while driving when throwing it out of gear into neutral that the revs drop to nothing and sometimes stalls.
I installed a fmic in mine last week too (r32 gtst) - same thing happened with the stalling. But it only did this for about 5 mins - then one of the silicon hoses blew off the piping. Turns out it was just not done up tight enough at one of the joins (must have missed it somehow in the rushed check:)
Anyway, once the connector was done up properly the stalling is gone and the idle sounds much better too. I'd check the connections, especially if one's got a bubble in it.
I think i might have fixed it. it didnt do it all this morning driving to work. last night i tried to fix up the bubble and its pretty well gone. think it might be slightly stretched. i spose we'll see over the next few days.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
