Just had a new alarm installed. It has engine and fuel immobilisers.
My old alarm, the immobiliser wouldn't activate unless the key was removed from the ignition. If the immobiliser had activated, all I had to do was press one of the buttons, even with ignition in ON position, the immobiliser would deactivate, and I could start the engine.
This new one - it activates about 30 sec after the engine is turned off. Even if I leave the keys in the ignition, the immobiliser will eventually activate. Then I have to activate the alarm (locks doors) then de-activate it before I can start the engine.
This means that even for something simple like buying fuel, to leave the servo I need to lock myself in the car, then unlock the car before I can start the engine. And the ignition cannot be ON to do this - it has to be in the ACC position.
This seems damn stupid - is it supposed to be like this? Does anyone else have an alarm that works like this?
https://www.sau.com.au/forums/topic/100522-new-alarm/
The guy that installed it (at my "tame" Autobarn) reckons that's the way they all work now.
Didn't get a manual, but will ask next time I see them (need to pick up my new DBA4000 rears). Must find out the brand while I'm about it.
With the old one, as I said, I could hit either of the buttons, even when IGN = ON and disable the immobiliser. Really seems stupid to have to lock yourself in the car first, just because you stopped the engine for a minute to do something.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1835165
so what's stopping you from going back to accessories and hitting any button? You shouldn't need to arm it to disarm it.
My alarm will let me disarm in acc or ON...
turn car off, leave keys or take them with me, fill up, pay, open door, key into ignition, turn to ON, press remote button to disarm immobiliser and give me ignition, start car.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1838895
My Mongoose alarm works in the same fashion too RANDY. However if I turn my ignition to ON while my alarm is armed, then it chirps continuously until i either disarm it, or turn back to ACC.
Blind: I know that if my car arms itself, then I still have to disarm it before I can drive away, as all it has done is armed the immobiliser and not the whole alarm. But I have never heard of an alarm that makes you arm it, even after it has armed itself, then disarm it.
- Crimpage.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1842953
But that's what I have to do. I have to literally lock myself IN the car, then unlock before I can start the engine.
As did my previous alarm. With this new one, I need to do it with IGN = ACC - cannot do it with IGN = ON.
My old alarm only activated the immobiliser once I had removed the keys from the ignition (as does yours). This one activates once the engine has stopped. The keys can still be in the ignition (like when I'm waiting outside a shop while my passenger goes in for something), and the immobiliser will activate 30 seconds after the engine is stopped.
Let me clarify - I'm only complaining about the immobiliser here - if the alarm is on, then the doors are locked, and I can't get in the car anyway.
I could do this with the previous alarm, too. If the immobiliser had activated, and I tried to start the engine, then the siren will beep - I simply press one of the buttons (IGN still ON), then the immobiliser is de-activated, and I can start the engine.
It needs to be FULLY armed ie doors locked, then disarmed before the car will start after the immobiliser has activated. That's the annoying part of it.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1843377
  • 4 weeks later...
i probably spent a fair bit more on my alarm then most people here...
my immobiliser wont activate until 30 seconds after the turbo timer stops OR 45 seconds after the alarm is armed OR 30 seconds of no activity (ie, jump out of the car with the keys but dont lock the car for any reason)...
the anti hijack subroutine will run everytime the drivers side door is opened and closed... (this is pretty annying, cause if you want to get out for a short while, you have to leave the door open...)
the car will not start, or even notice the key is in the ignition unless the immobiliser has been dissarmed, which is easily done...
plus if any of the many sensors go off, the car will call me and let me know...
what? im not paranoid...
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1907849
my immobiliser/alarm arm as soon as the car is not running after 40 seconds.. this includes when listening to just the stereo.. which means I have to press the button to disarm it otherwise it goes off when I try to start the car..
personally this isn't really a bad thing.. it means if I leave the car atleast somone can't just get in and start it and drive off (unless it's under 40secs)..
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1911041
it arms the immobiliser - however the sensor alarm isn't armed until you lock the car..
if I turn the ignition on without disabling the immob. the alarm goes off..
I can sit around do everything I want, listen to stereo, turn lights on.. just not put the car to on..
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1915168
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
