Just had a new alarm installed. It has engine and fuel immobilisers.
My old alarm, the immobiliser wouldn't activate unless the key was removed from the ignition. If the immobiliser had activated, all I had to do was press one of the buttons, even with ignition in ON position, the immobiliser would deactivate, and I could start the engine.
This new one - it activates about 30 sec after the engine is turned off. Even if I leave the keys in the ignition, the immobiliser will eventually activate. Then I have to activate the alarm (locks doors) then de-activate it before I can start the engine.
This means that even for something simple like buying fuel, to leave the servo I need to lock myself in the car, then unlock the car before I can start the engine. And the ignition cannot be ON to do this - it has to be in the ACC position.
This seems damn stupid - is it supposed to be like this? Does anyone else have an alarm that works like this?
https://www.sau.com.au/forums/topic/100522-new-alarm/
The guy that installed it (at my "tame" Autobarn) reckons that's the way they all work now.
Didn't get a manual, but will ask next time I see them (need to pick up my new DBA4000 rears). Must find out the brand while I'm about it.
With the old one, as I said, I could hit either of the buttons, even when IGN = ON and disable the immobiliser. Really seems stupid to have to lock yourself in the car first, just because you stopped the engine for a minute to do something.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1835165
so what's stopping you from going back to accessories and hitting any button? You shouldn't need to arm it to disarm it.
My alarm will let me disarm in acc or ON...
turn car off, leave keys or take them with me, fill up, pay, open door, key into ignition, turn to ON, press remote button to disarm immobiliser and give me ignition, start car.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1838895
My Mongoose alarm works in the same fashion too RANDY. However if I turn my ignition to ON while my alarm is armed, then it chirps continuously until i either disarm it, or turn back to ACC.
Blind: I know that if my car arms itself, then I still have to disarm it before I can drive away, as all it has done is armed the immobiliser and not the whole alarm. But I have never heard of an alarm that makes you arm it, even after it has armed itself, then disarm it.
- Crimpage.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1842953
But that's what I have to do. I have to literally lock myself IN the car, then unlock before I can start the engine.
As did my previous alarm. With this new one, I need to do it with IGN = ACC - cannot do it with IGN = ON.
My old alarm only activated the immobiliser once I had removed the keys from the ignition (as does yours). This one activates once the engine has stopped. The keys can still be in the ignition (like when I'm waiting outside a shop while my passenger goes in for something), and the immobiliser will activate 30 seconds after the engine is stopped.
Let me clarify - I'm only complaining about the immobiliser here - if the alarm is on, then the doors are locked, and I can't get in the car anyway.
I could do this with the previous alarm, too. If the immobiliser had activated, and I tried to start the engine, then the siren will beep - I simply press one of the buttons (IGN still ON), then the immobiliser is de-activated, and I can start the engine.
It needs to be FULLY armed ie doors locked, then disarmed before the car will start after the immobiliser has activated. That's the annoying part of it.
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1843377
  • 4 weeks later...
i probably spent a fair bit more on my alarm then most people here...
my immobiliser wont activate until 30 seconds after the turbo timer stops OR 45 seconds after the alarm is armed OR 30 seconds of no activity (ie, jump out of the car with the keys but dont lock the car for any reason)...
the anti hijack subroutine will run everytime the drivers side door is opened and closed... (this is pretty annying, cause if you want to get out for a short while, you have to leave the door open...)
the car will not start, or even notice the key is in the ignition unless the immobiliser has been dissarmed, which is easily done...
plus if any of the many sensors go off, the car will call me and let me know...
what? im not paranoid...
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1907849
my immobiliser/alarm arm as soon as the car is not running after 40 seconds.. this includes when listening to just the stereo.. which means I have to press the button to disarm it otherwise it goes off when I try to start the car..
personally this isn't really a bad thing.. it means if I leave the car atleast somone can't just get in and start it and drive off (unless it's under 40secs)..
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1911041
it arms the immobiliser - however the sensor alarm isn't armed until you lock the car..
if I turn the ignition on without disabling the immob. the alarm goes off..
I can sit around do everything I want, listen to stereo, turn lights on.. just not put the car to on..
https://www.sau.com.au/forums/topic/100522-new-alarm/#findComment-1915168
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
