  • Replies 40
He knows his stuff and he's a jap enthusiast, unlike the only SA ecu chipper who simply doesn't appear to give to sh*ts about jap cars these days. Its all V8's, black jeans and thongs for him. :rolleyes:
Nice call joel, the SA guy now bags out small jap engines, he seems to have forgotten that turbos originate from japanese cars and if it wasn't for the import scene he probably wouldn't have a turbo bolted to the side of a LS1 V8.........
Nice figure but no one can ever really trust there output...all it takes if for them to set it up with u being above sea level or what ever u go and u can grap and extra 30hp....
All dynamics dynos are equal in shootout mode. That is why they implemented it, so that tuners could accurately compare results. It's not right when people say...."oh but on Joe Bloggs dyno it reads less (or more) than it really is". If it's in shootout mode - everyone is equal.
Edited by 3lit3 32
Not quite. There are still variables that have to be entered by the operator (such as the barometric pressure as mentioned), as well as the temp correcton on the intake temp that can be used to fudge results.
Something for you to have a look at on shootout printouts is the difference between room or ambient temp (RT or AT) vs intake temp (IT) and consider that an 8 degree difference between ambient and intake netted me about 10rwkw on the print out.
I'm often a bit sceptical when there is a difference of more than 10 degrees considering mine was an unenclosed pod and the car had completed about 10 200rwkw plus runs and only recorded a difference of 8 degrees. I recently saw a 250 plus rwkw s14 go through the same situation with the same sort of temp increase. As a result, that is often the second thing i look at when a dyno sheet seems to be a touch high (first being the power figure).
My air temp vs intake temp was 30 deg vs 34 deg which would sound about right. I didn't ask the guy for a straight out power run, I asked him to check AFR's....
The only bad thing to come out of it was that my car now seems to have a very slight miss when idleing which wasn't there before.... seems to miss in quite a random fashion..... not like its missing on 1 cylinder every time, just sometimes.... but I can live with that if the car runs fine through to redline. I'll probably need new coils in the future.
I think I may settle for an old SAFC in the future too.... I really only need to move my AFR from sitting on pretty much consistant 10:1 all the way to redline, up to 11.5 AFR. I think it would be pretty simple with an old SAFC.
Fixxxer :P
I would lose the ecu mate.
I reckon the timing map would look pretty nasty, it would be sailing pretty close to the wind. Thats something a SAFC is not going to fix either.
3 things you should always have tuned with a margin for error;
1) AFR
2) Boost
3) Timing
Each one yeilds more power as it approaches the danger zone. In your case the lowish boost and rich AFR's are probably helping things, I wouldn't be in a hurry to go leaning things out with a S-AFC.
D'oh, not something I wanted to hear.
The guy who dyno'd the car said there was "already a lot of timing on it" when I asked him about the timing.
He also had the other workshop guy lean over/into the engine bay and listen..... for what I gather was any pinging that may have been occuring. He did this for the last 2 dyno runs and the guy gave it the thumbs up for both runs.
I'm starting to reconsider any more mods and only give it a boot full when the weather is cooler or night driving, just to be safe, this is after all, my daily driven, I don't want to break anything. My old car had the same power but only weighed 930kg, gotta get used to a larger/heavier car and live with it.
Fixxxer :P
Fixxxer :P
I'm sure they knew what they were doing but they should have known better.
The closer you put your head to the engine...the harder it is to hear pinging.
You can hear pinging a lot clearer from 10 meters away than you can from 10cm.
I hope they have done the right thing by you on the tune as I know of plenty of tuners who just blow through it and don't actually spend the time needed.
Cubes,
I reckon he needs to ditch the jap chipped ecu before he goes and gets a S-afc. Why touch the AFRs if you are running a mickeys hair away from detonation on the timing map?
Swap/sell the ECU and get a stockie + SAFC is a solution but, the adjustable timing map is a top thing to have. Re-map the ecu locally is a very good idea if thats something he can do.
Hey guys....
Just to get back to my ECU, I never had the ECU mapped.... its the ECU that came with the car when I bought it, so no tuning was done when I had the car dyno'd.
I've been thinking about it lots and taking peoples advice... If I did get a SAFC I would take timing out of the car to be safe with the leaner mixtures. I'm probably going to put it back to 0.6bar on my Profec for everyday driving anyways.
Fixxxer :P
Unfortunately if the ecu in the car has jap chip in it, the actual timing map is going to remain even if you retard the base timing. The S-AFC in that case might be one step forward two steps back.
Dropping the boost down to 0.6 bar gives you some head room to adjust the AFR's using a S-AFC however. The S-AFC II can also monitor knock levels.
Ok here's a new question which is a bit controversial.
Should I run on Shell Optimax Extreme 100 to be even safer? (In terms of the possible jap ignition advance on it)
Ohhh and does anyone know what all the stuff means on my early model Profec. Its got 3 small dials on it on the right, an overtake boost button, a nob that seems to go in 0.2bar increments of boost and a red LED panel that reads -.5 on idle and varies as I accelerate, I don;t think it ever makes it into positive readings, but when I'm on boost I'm usually looking at the road :(:)
Could I set my boost from 0.8bar to 0.6 bar and just use the "overtake boost" button if I want to give it a little?
How long does it last for? How much extra boost do I get???
I tried doing a search before but came back with lots of Profec B II stuff...
Fixxxer :)
Edited by Fixxxer
*shrug*
It does blow a teeny bit of black smaoke up high on boost, so I don't have a reason to think its not running rich to some extent.
And it does feel strong up top. I guess the only way to compare to other cars is to go to a dyno day and compare with others on the same dyno, same day thing.
Fixxxer
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
