Plan on taking our extensively enhanced GTR R34 to Tassie for a short trip. As there is no 98 octane fuel available there it has been suggested to lower my boost to say .8 bar ( currently it is configured through an Apexi AVC-R boost controller at 1.2 bar) and use a good octane booster with premium fuel (95 octane) which is available over there.
Any one had any experience or comments re the suggestion ? I'm presuming these octane boosters work.
Of course being a retiree the beast probably won't even get to its boost parameters (chuckle). What am I saying! I lie.
https://www.sau.com.au/forums/topic/100810-octane-booster/
octane boost is good, only use it if you have to... e.g. when your using 95 or when ur gonna race someone :D
i've used it before and yes i feel the extra boost not much but it works magic :) cheers hope that helps
also the come in different brand but the all work the same u wont notice the difference in brand unless u put it on a dyno and you wouldn't wanna waste ur time seeing which one is better they all do the job. :)
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1839782
Be careful using octane booster! I, personally will never use it again!
Recently I had to use octane booster due to the lack of 98 ron fuel. Not long after using it my car developed a 'miss' during idling and acceleration.
After taking the car to my mechanic, the spark plugs were removed and had to be replaced. As soon as my mechanic saw the condition of the spark plugs he knew that I had been using octane booster and hadn't told him.
Rarely do I drive the car hard as I value my licence and my car too much! Not sure how common this kind of thing is, but just thought I would let you know of my experience with octane booster and why I will never use it again!
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1840016
I'm pretty sure octane booster only adds 1/10th of a RON...so you can go from 95 to 95.1 if you add a bottle....not good enough.....
Also AFAIK there is only 95 octane at one place in Hobart and that won't get you around the whole state.
At targa we run 98 octane, nothing special, but we have to get it trucked around the state it drums.
I reckon the best thing to do is turn the boost as low as you can, and retard the timing a few degrees, I'm sure Ali can give you a hand.
Maybe post up in the Tassie section and see how thsoe guys are doing it? Its a great place for a driving holiday, enjoy!
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1840031
It says on that pretty spec sheet that it's running a Powerplay-tuned ECU.
Best bet is to call Alistair and ask him what fuel he tuned it to... Hopefully he tuned it on 95 for safety, but if he tuned it to 98, just turn the boost down a bit like you planned, and she should be fine. If you're REALLY worried, get the timing retarded a bit.
Forget those octane boosters. They don't work and just foul your plugs.
edit: Damn you Dundan, stop copying me :D
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1840283
Hmm.. wasn't aware of the fact that tasmania is so removed from the rest of australia and doesn't have 98RON.. was thinking about doing a road tour down there..
What do all the Tassie people do for fuel?
I'd check what they say in their little forum area. Good luck - let us know..
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1840296
maybe you need to run hotter plugs.
octane boost will give a brown layer of crap over your spark plug tip. it will eventually need to be replaced but it wont immediately effect a decent set of spark plugs.
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1842011
As Duncan said above, octane boosters only raise the octane level of fuel one or two tenths of a point (0.1 to 0.2) at best. They are a waste of money and would be better sending the $20 or $30 on regular fuel instead, whilst running less boost and not loading the engine too much. Retarding the timing is the best insurance against detonation.
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1842501
what a lovely looking car. not bad for an old retiree. much better choice than a tinny and a caravan. hehe. very nice taste indeed!
duncan, andrew and nxtime have the right idea. octance booster can cause more trouble than it's worth. start with a full to the brim tank (of 98ron) before you hop on the ferry then try and fill up when you still have half a tank left. that should effectively give you a full tank of 96.5 octane (plus you have been able to use half a tank of 98 in the meantime). do the same again at half tank and you get a tank of near enough to 96 octane. after that, you are down to pretty much straight 95. which should be fine on your low boost setting. just keep a little eye on your MFD for anything abnormal, and have fun.
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1847794
I had NGK spark plugs in it, almost certain they were NGK iridium spark plugs, aren't they supposed to be good?! Are there better plugs?
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1849704
Guest Mashrock
eh? Tassie has the best driving roads in Aus.
And I'm sure that with standard boost and a few degrees timing retarded you will still be able to get to the speed limit ok......
they have speed limits in tasmania?
p.s. say hi to uncle chop chop for me
Edited by Mashrock
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1850647
From the BP web site..............
2. How can I boost my octane?
The octane of a fuel can be boosted by adding proportions of a higher octane fuel. Also available is toluene, which can be used as an octane booster in both unleaded and leaded fuels. Generally each 5% addition of toluene will increase the fuel's octane rating by one number. It is not recommended to add more than 30% of toluene to the fuel. Because of the dangers with incorrect mixing, individual motorist are advised against mixing additives with fuels without first consulting their car engine manual or their fuel supplier.
So check with the Tassie guys where you can get toluene.
:P cheers :D
https://www.sau.com.au/forums/topic/100810-octane-booster/#findComment-1853026
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
