hey guys
wanted to do a little write up about the ceff and the lag problems it has had. fitted a hks 2530 for reason of minimal lag and reasonable power output achievable. with supporting mods - fmic / 2530 / pod / zorst / bleed valve / fcd / bov achieved 225rwkw!!! but it came with massive lag :P --see dyno graph
so to sum it all up wasnt very happy with it - changed things along the way to 'test' and make it less laggy - slowly but surely and on a budget this is the results 213rwkw (but more fuel added for safety)
things that were changed to assist in helping the power delivery come on a lot earlier were
-hks evc III
-hks 1BAR adjustable actuator
-nismo lightened flywheel
it probably doesnt sound like much but the difference is ridiculous - originally boost wasnt hitting hard until you were pretty much on the limiter! and this was in second gear!!!
another thing which i was surprised about was. i was able to borrow a remapped computer from a mate to suit rb20 and hks 2530 and doing power runs on standard comp with HKS FCD and straight after swapping to remap the results were IDENTICAL!!! so stock computer it stays :P
anyway hopefully now i can focus on 'driving'
thanks to ppl who helped with it all - RYAN / TERRY / SIMON / LYNDON
so just beware the hks2530 on rb20det may not be exactly your choice in turbo upgrade and if upgrading i wouldnt mind seeing how a hi-flowed steel wheel rb25 turbo would be...
https://www.sau.com.au/forums/topic/100894-lag-problems-rb20hks-2530/
  • Replies 57
Posted Images
With those added bits and pieces, obviously you had more control over the boost cycle in each gear etc using an EVC, but was there and increase or decrease in your torque figures? Where you running identical boost pressure with each dyno run, basically, looking for a reason for the 12KW loss...??
the loss of rwkw - was from more fuel being added as it was starting to get a little lean on 225rwkw. so now with more fuel added back in it is making the 213rwkw. with fuel now in the 11's it is a lot safer especially when it is basically a track/thrash/drift car
this is the same boost setting aswell in both power runs. at 1BAR
the lightened flywheel seriously felt like it made a difference! as opposed to the stock flywheel it helps spin easier because it's lighter - meaning it helps revs build up quicker and boost. (well thats what i'm guessing lol)
there was a HUGE increase of torque in the MIDRANGE.
originally i was very disappointed with the turbo and was 99% sure was going to put a stock rb20 turbo back on. it was that bad! BUT now it is a lot better.
just thought i'd post it up as i know of at least 2 other guys with similar lag problems from a hks2530 and hks2510 on rb20's
made 190kw with a highflowed rb25 turbo on my rb20 at 14psi
little disappointed, but it was running on just actuator, no boost controller :)
lag is pretty huge, turbo starts spooling 2.8-3.0k but doesn't make fullboost till maybe 4.5k
Edited by nF
lag for 2530 maybe but 2510 on stock motor pffft they are LAG FREE unless you got serious issues with your timing
yep well lindo 'was' having lag issues with his 2510... once again the 1BAR adj actuator did make a big difference for him aswell...
and that is very interesting about the rb25 turbo!!! thanks for the info :)
another thing - check your actuator isnt dodgy (remove dump pipe and make sure wastegate is shut firm)
a dodgy way to increase your boost and also possibly reduce lag is to put a kink in your actuator rod (creates more tension) this may help if you're on a budget? or get a adj actuator rod... :)
I've seen this problem a few times in the last couple of months and every time it is the actuator, either set too loose (when adjustable) or still running a stocker.
This is on cars running decent ebc's aswell.
As for the highflow on an rb20. I ran an old stage 2 GCG and had 14psi by about 41-4200rpm using only an hks adjustable actuator. The current highflows are a bit more responsive than those ones.
nF, you'll find the boost curve will be an almost vertical line once you start winding boost in on the highflow. It will slowly build up to about 6-8psi over 1000 rpm or so and then just shoot up to what ever you decide to run in the next 200 (big turbo/small engine type response). You probably wont be able to spot the difference in spool time unless you plot runs back to back on a dyno.
Good to hear the Ceff is going alot better now Huddy, was alot of fun trying to tune your HKS EVC III around Pt Wakefield, had boost response like a light switch :P
You still running about 1.1BAR through the 2530?
Cant wait until to see it out on the track again some time soon
Gettn a new turbo for my Ceff tonight, RX7 S5 comp, high flowed RB20 turbine, i hope its not going to be too laggy...
Hey A31drifter, the rb smaller capacity per cylinder, be a shorter stroke than the SR there for less mid range and harder to spin the turbo up. think thats correct in short anyway
I have a 2535 on my rb20, I dont find it a problem wouldnt get too worried its a little laggy but it slams it on.
Edited by cefiro
I am running the stock actuator on my hks 2530, running 1.2 bar thru and ebc and have no issues at all. Infact i sold the hks adjustable that came with it becayse SK doesnt recomend the adjustable type.
Ive put the VG 30 turbo BB on my rb20 Ceffy but had to replace the engine before i could dyno it. Has anyone done this turbo set up and what results did they get??
I'm also running GTR fuel pump, 3" exhaust all the way through, twin dump pipe and bleed valve set at 18psi, Blitz BOV and pod.
Engine goes in next week and I will send her off to the dyno for figures, Which i'll post up
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
