  • Replies 123
have you got pics of the kit installed.
i just want an idea of what the r32 gtst piping kit looks like and where the pipes run ?
how much for just a r32 gtst piping kit ?
cheers- Ricko.
Same question, need piping only.
Hey man,
the PM's your sending dont seem to be coming through :(
Could you please copy paste what u wrote and email it to me at : [email protected]
Would appreciate heaps!!
Cheers,
Dan.
hey mate, i would like to know this before i buy... is there any cutting required of the standard type m front bar on an r32 gtst and do i have to chop any of the fan blades or cut a hole in my chasis like the just jap cooler kits??? cheers mate
you will need to chop the f**k out of the stock type-m r32 bar (i had to, and it needs tidying up atm). basically i found i had to cut a heap out of the centre hole including the vertical support bit, and completely cut out both the side holes in the bar.
i didnt have to chop the fan blades on mine. i just made sure the exhaust piping was pushed up against the cam cover and away from the radiator blades. you will need to cut a hole through the side part of the engine bay just below the battery compartment though.
the gts kit is very generic though, as it is made for r32/r33/r34. i found the support on one of the pipes was useless for my rb20det (the one that is sposed to bolt onto the engine block).
pm for pics if you want
Edited by flagger
3/ Hybrid RS spec kit (core - tube and fin - 580x295x95) - $730 delivered.
Got this in stock for JZA80 Supra?
Send me a PM or email. Ill gladly buy one of you. Thanks
PM sent.
:laugh:
couple of questions -
ok yep bar and plate or tube and fin?
fitment to a 97 stagea id IMAGINE is the same, being the same engine bay, same R33DET engine. anyone else know?
haha will await your PM.
1/ HDI GT spec kit (core - tube and fin - 600x300x76) - $630 delivered.
Will this fit an R33 S1?
Cheers
Jamie
Yep, will fit.
PM me ur email addy if you want a copy of the install guide.
I would like the 'bar and plate' monster kit to suit r32 gtst. Can you supply me pics of the actual kit please!
I also need payment and delivery details.
Thanks.
Edited by HR-32
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
