Hey Guys,
Currently in mr Stag I have a full Pioneer system.
- Carosseria Headunit
- 12 Disc Pioneer Stacker
- Kevlar Splits
- 260w Coaxials
- 1000w Pioneer Sub
- 800w monoblock amp
Now I have since aquired a sponsor. Blaupunkt. Now I have never actaully heard any of their systems. Anyone got a Blaupunkt System?
Anywho, this is the new plan.
- 2x Velocity VC650 6.5" Splits 120w RMS (Front and Rear)
- Velocity VX652 6.5" Co-axials 120w RMS (Mounted on back Pillars)
- 3x VW 1200 12" 1200w Sub (Mounted 2 facing out, 1 facing in)
- In Dash DVD player touch screen
- 2x 6.5" Headrest Monitors
- 3x Velocity Monoblock 1x400w amps
- 1x Velocity 4 channel 4x100w amp (For the splits)
hmmm....yeah thats about it. What are your thoughts?
https://www.sau.com.au/forums/topic/101336-my-new-audio-set-up/
Blaupunkt are pretty good. They will rival most other brands out there at the moment. I would especially take it if they are a sponser and that stuff is cheap / free...
One thing tho... I wouldn't use a 400W amp on a 1200W sub... You are always best to have more power than needed when powering a sub. Otherwise you will find that the amp will either go into protect mode (when up loud) or the amp will start to distort before the sub does and will try to make the sub reproduce its lovely distored sounds and cause damage to the sub.
- Crimpage
Take a look at the true RMS figures on the sub (if they will tell you) I wouldnt be surprised if that was 1200w in good conditions for 3.5 sec. I would imagine you will be tunig the system to play below the point of distortion anyhow :O Anyhow, all this gear should sound pretty smegging good, id' love to see some photos when she's done.
Well because you will find when you go for sponsorships 9/10 times you will get a Quasi sponsorship. Heavily discounted. I am not at liberty to say how much though... Contract :( But yeah, I'm currently in negociations for a full sponsorship. They just dont hand them out to anyone though.
If you want a sponsorship, have a talk to some companies. Pitch some ideas, sell yourself :)
  • 3 weeks later...
nope, seen quite a few blaupunkt head units though, quite good... different and unique...
the information on the sub on their website says that the 380 sub (1000watt rms) has a frequency response of 25 - 1000hz, but like every other place, they dont state a price, they also dont say shit about it being either a dual magnet, dual voice coil, the strength of the magnet etc...
normally that isnt stated for a reason, so i can only assume that it is a single magnet single coil, meaning, if it is powered correctly, it will burn out the coil pretty fast...
due to lack of info, and better options out there, i wouldnt pay more then 300 for one of those, even then, i know better subs to buy...
and as for your contract, ANYONE and EVERYONE can and should get discounts on electronics... never buy the sticker price, they are rediculously priced... if they say they cant give a discount (and its not on special) ask what you have to do to get one, if they say they really cant, f**k em...
Blaupunkt are ok, they are usually more associated with head units though, but have a nice range of stuff. Its not high end, but better than some.
I can't believe they only have a 400WRMS amp (I gather its a mono amp). Thought they would have had a more powerful version, especially if they are quoting 1000WRMS for some of their subs.
The 12" VW subs that are 1200watts are probably only 400WRMS.
You won't 'burn out' a coil.... If you overpower the sub then your a good chance at it. It doesn't matter how many coils there are.
Stick with the power recommendations from the manufacturer, keep your amp gains adjusted appropriately to prevent clipping and they will work for a loooonng time.
Fixxxer
Fixxxer
Thanks for your help champ. The VW subs are 1200w rms each :huh:
C'Mon People. Someone must of heard or own a Blaupunkt sub
what would you like to know about the brand.( I sell the complete line.) also did you chat with the dealer or the manufacturer?
the screen you mention hasn't been released yet. I'm waiting on one currently.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
