  • Replies 76
After I received my PFC the otherday a mate of mine's interested in one too.. 2 questions..
1. As Satanic has just asked.. can you get them for 180sx' .. Or more particularly can you get them for SR20DET 180sx'?
2. Will there be another or when is the next group buy? or can we arrange another unit or two?
Cheers and thanks again for my powerfc :whoops:
Hey mate... How things? Just wondering if group buy seven is still going for power FC with commander? If not, when do think the next one will be? Cheers mate
(sorry for RB20)
Edited by Savage Bliss
Hey Greeddy - Mate enquired before about using with Rb20 Cefiro & thanks for checking that out for me!
Due to that engine dying I am transplanting a R33 GTST RB25 into it. Is there a PFC that will work...ie standard R33 GTS-T??
Also is it 'series specific' ie series 1 engine are a little diff to rest.
Cheers,
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
