Guys;
most of us are aware of the crushed sill (not chassis rail) syndrome afflicting R32 GTRs - and maybe other models. I'm talking about the flattening of the spot welded vertical seam forward of the front jacking point, behind the front wheel arch. hope that makes sense.
usually happens when the thing gets jacked, or lifted on a 2 post hoist, and just about every 32 GTR I've seen has had this happen.
has anyone come up with a surefire way to fix it? i'm sick of having to tell people not to lift it on the sills - either they do it anyway or I spend the day wondering if they've taken notice.
there's got to be a way of making a permanent professional repair. a search has revealed that others have had the same problem but not if a good repair was carried out.
i haven't seen that section cut open to know if it's even really fixable - seems to have the robustness of an eggshell so maybe a couple of 'no jack' stickers is the best defence - for those that even look before they jack.
any ideas?
regards
Edited by Scooby
https://www.sau.com.au/forums/topic/102145-crushed-sills-on-r32-gtr/
i just use a shifter to streighten them out
i think they bend in when the car is to low and scrape on the gutter or something???????
To answer these in the wrong order...
Don't use a shifter - if you want to do it this way get yourself a set of wide nosed multigrips. They lock in place making it much less likely you will damage your car or yourself.
The blokes at the pits don't really care about the rocker panels (Technical term), but can get a little worried about bent up chassis rails. They also get a bit concerned with signs of rust in the rails & particlarly if they have been bent & refilled with any sort of body filler.
one of my rails is comletly crushed, so i bought a new one from nissan for about $200 and willbe getting it replaced. the rest of the rails are also bent in through the center but nothing major.
when i get them fixed the guy wont cover them in anything so the guys at the pits can see he's done a good job. then ill get them coated.
im real worried they wont let the car pass though :P
The outer sill panel is welded to the car at both ends. The panel shop cuts the existing sill out an welds a new one in. I'm pretty sure we're on the same page because you couldn't pull out a chassis rail with multi-grip but could give it a good go on a sill.
When mine was welded in the panel shop was going to cut out a section of the rear panel but ended up fitting a new one. You'd need to paint afterwards to tidy up. If you are just pulling it out rather than replacing, then sure, no paint. My car seems to have had rust cut out of the sill on the driver side. A really dodgy job with a terrible weld job. I'm really pleased we found it and replaced the sill, it looked shocking, I'll see if I can drag out the pics.
I still have the rear quarter glass, it's just taking up space in the garage :P If you're interested Scooby, please shoot over a pm
  • 6 years later...
Resurrecting an old thread here. I am also suffering from the typical crushed sills from my car being lifted on the sills when on a hoist. I want to get my sills repaired/replaced, but want to stop them from getting damaged again once fixed.
Any ideas?? My mechanic generally only uses the sills on the front of the car, as he lifts the rear of the car using part of the rear suspension (the rear lower arms I think).
Has any one here done anything to strengthen the sills, or do you lift on different points ( other than the sills) when on the hoist??
I see in the R32 GTR manual, they use some sort of rubber block with a cut out for the sill to lift the car from the sills. Has anyone used something similar??
Any assistance/ideas appreciated.
Anyone??
Anyone??
For me Im thinking to straighten the sill as best i can with the multi grips.
And then cut and remove sufficient space for the Pads on the car hoist.
Obvioulsy cleaning up, rust proofing and painting the area.
To get it back to how it rolled out of the factory then yes will have to buy new sills and replace.
Then tell every shop you go to not to use the sill area to hoist the car up when working on it.
Perhaps you could make the rubber blocks to take with you to the shop?>
Thanks Richard. I was also thinking of straightening the sills out, then cutting some out for the hoist pads. Will also rust proof, then paint etc. Just hate the look of my crushed sills and the thought of rust creeping in there. Yes, paranoid I know!! :yes:
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
