Official Sauwa Cruise. Saturday 28th Of January
  • Replies 86
I left after the second meet stop.
Was no fun after cops rocked up and took a map and were a long the roads pulling people over. All though the guy that got pulled over didnt get a sticker or any fines.
was there more sign of cops after that?
btw driver I want your engine in my 34.
Edited by noise
Man, nearly 2am. Time to make some z's
At least the cops didn't start inspecting cars at the second point or call a blockade somewhere along the way.
It seemed everytime I was driving up to a green light that suddenly went orange, it was a friggin Red Light Camera intersection......I hope I didn't get done ($150 and 3 points for that...)
good cruise :)
thanks to liz and dan for doing all the hard work :)
too bad about the cops :( i think they like dan :angry:
Cheers Michael :)
P.s sorry to driver for putting my highbeams on HID where playing up and just went out :S (if anyone saw a r33 with 1 headlight on or 1 jumping on or off thats me hehehe)
Wat the f**k happen to you dan
the night had everything appart from murder and romace
thank you jarrad and your misses + pulp 4 your hospatalaty
and my misses even enjoyed herself
some crazy mofos tho
and dan wat happend
james
Give me your liver and ill think about it :(
Thats okay michael - i saw you fiddling with ure headlights before we took off - for a while i thought you were just playing stealth mode when you turned all your lights off for about 30 sec :angry:
Thats okay michael - i saw you fiddling with ure headlights before we took off - for a while i thought you were just playing stealth mode when you turned all your lights off for about 30 sec :D
I was behind him, when his lights went our around the corner. i was thinking what's this crazy f**ker doing?
Thanks Dan & Liz!
Good cruise, wasn't that bad with the cops, they didn't cause any problems, appart from Dan :D Was worried too when they took the map, but all went well!
Good to meet some more of the ppl off the forums. Some nice bluddy cars! Good to meet you James and your gf.
Dave.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
