John - isn't your best time 1.07.7 ON SLICKS compared to giants cars best time of 1.06.6 on semi's? Or has that time of yours changed?
I know Marks Winton time was 0.4s faster than mine at Dutton last year but I'm sure we have both done more to our cars since then so I'm keen to see how our cars compare now.
  • Replies 503
Posted Images
Hey John
i'm going to smash that time this weekend! going to the hks drag meet at willowbank this weekend to see if i can break it! :P
wil be good to meet finally!
hey pete i have standard r32 gtr radiator laying around if you want me to bring it down to wakefield.
cheers russ
In the Zeds defence the slicks he seems to run always look cactus...so thinking abot how Yokos and other semi tyres go off?!?!?!?!
Some fresh semi slicks on the ZED will be interesting.
I still say the GTST can do a 1:10 piss easy, more like low 1:09s. So 1:06-1:08s are on the table. Just how mnay cars get into the 1:05s will be interesting
LOL...Fatz has got tyres for his car. Next thing he will be getting it tunedm, a wheel alignment, hell even a wash :D
i really was looking forward to coming down wednesday night and having a drink at the cabins, but i now have to go to a meeting wednesday night that i cant get out of. DAMN IT!!! i will be there Thursday morning.
mark will be there wednesday night.
will bring the radiator down too.
Cheers Russ
come after the meeting lol
i highly doubt Troy or myself will be in bed... after all... Troy loves sitting on park benches waiting for the sunrise... although sadly he generally passes out before that happens :D
Hey i may pass out, but the first crack of sunlight usually has me waking everyone up looking for a St George :P
Tell me again how you got selected infront of 230+ other people Pete??
LOL
well on the entry it wrote
exterior mods.... "shit hot gliter paint with 22 inch spinners for the street"
also wrote r31 number one about 50 times
and i slept with the editors cousins dogs trainersc mother...
:thanks::woot:
:yes::yes:
:banana::banana:
Well Snowman I did a 1 min 6.57 in December dodging slow HQ's on old slicks. I am sure I will be faster on new semi slicks, only prob is they cost money. If I don't do a 1 min 5 I will be disappointed. Although it will be harder for all of us putting it together in basically one lap.
Fatz spinners hey bit of bling for this event, that's the spirit.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
