Hi all,
Getting on the track for the first time next month, got a couple of questions
What sort of helmet is best?? I would think open faced, and they need to be ADR approved right? and motorbike style helmets, just they'res some nice open surfing helmets etc.. on ebay. Where do you buy them from?? any other places than motobike shops (who charge an arm and a leg).
was thinking something like this:
http://cgi.ebay.com.au/Excellent-Black-ARA...1QQcmdZViewItem
Searched for tyre pressure and could only find one post where they said 40psi is best - i have hankook k104 235/45/18s on the front and falken ziex (yes crap i know) 265/35/18s on the back.
Any other advice for a track noob??
Cheers :D
https://www.sau.com.au/forums/topic/103019-first-time-trackday/
Hi all,
Cheers :)
An open face helmet will be fine if that is what you want. I use an open face Arai because I get claustrophobic in a full face helmet. It should be to the relevant Australian Standard (or an FIA standard such as SA2000 or just recently SA2005). See schedule D of the CAMS manual for a full listing. They don't have to be very expensive, but remember cheaper usually means heavier & in an accident heavier means more damage to your head. Depending on how serious the event is you may need such things as a level 2S CAMS license. No big drama.
Most important thing to remember is - HAVE FUN. Most people suck really badly when they first start - it is only by practising that you get better. Look after your car - particularly your brakes & if others are coming to overtake you stick to you line & allow them to go around. It works much better that way. So enjoy yourself, talk to your fellow competitors & if possible follow someone around the track who has been there before and knows which lines to take through the corners.
Edited by djr81
  • 1 month later...
You think you may know the lines, but you wont. Follow someone else who is doing well and over taking everyone and just try and stick to their line. If you can mimick them it will give you a starting point on the what line to take. I found that the best way to get a descent start on my first race meet. Last race of the night i ended up coming 5th outta the 20 odd cars. Thought that was pretty good for my first time racing. First two race were shit house though, came like 14th and like 11th. So dont expect too much of yourself.
Enjoy it. Its great fun.
I race a white r33 with a really lame sticker configuration on it which my father chose. Gold rims. Might see ya around sometime.
re helmets go closed face if you can, some operators won't let you use open faced, and if yuo even drive an open car you wont be able to use an open faced helmet either.
The most important thing about a helmet is whether it is comfortable or not....so pay the extra, go to a bike shop with a big range and try on everything until you are happy. They need to be snug but not tight and if you wear them fir a while yuo will feel the difference in shape some are really uncomfortable for some heads.
Tyre pressures...with road tyres keep them nice and high, between 40 and 45 hot. The 326s are shit and will ruin your fun for the day, so when you buy new tyres buy something decent it makes an amazing difference.
Other advice...same as r33_racer.....road driving habits are no good on the track, when you are out for yuor first time you will brake way too early, turn in to the corner way too early and go thru the corner way too slow....ideally you should take the time to go out with someone who knows what they are doing you will be amazed how different the right lines are to what most people take.
And take it easy at first, you car is a road car and will overheat - oil, brakes, tyres. If you want to stay out there do 3-5 laps then 1-2 slow laps, then back on it again. Keep an eye oil temp and water temp.
And take a break it is hard work and when you are tired you make mistakes :)
And enjoy!
such a good point. i used to always try and be the enduro hero and do all laps in the session. it's not always a good idea as you will just wear out your car that much quicker. you car may only last 2 10 lap stints but could have lasted 5 or 6, 5 lap stints.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
