  • Replies 717
HUGE DAY possibly the biggest dyno day on record certainly for us. Anyone been to a bigger one?
Adam great job and not easy hey. Big well done. Most enjoyed the day and some thought our air fuel ratio was lean and then some rich so not consistent either way, so guess it is right. We did have the odd problem with air temp sensor which had a dicky plug new one ordered a few weeks back and arrived today, bit late. The inlet temp reading went through the roof, like 150c and so dyno compensated and gave a few rare cars huge power so rerun and all were right in the end. Some cars pinging whether customer wanted to believe it or not. Some only slight and one R32 GTR fairly stock pinging quit a lot and running lean so could save his engine by coming this day. We would have liked some time to do some demo's and before and after but I think over all a great day. Beer Baron you consistent jocularity would ahve been welcome on the day as always.
MIK
It actually WAS strapped down when it did that, then they decided to strap it a bit tighter.
In the first place I had to ask Ben about 6 times to strap it down
Ben is a great mechanic and tuner not so friendly. He was also under immense pressure mentally and physically and takes his work very pationatley and serious. I have had or tried mech's who are talkative and super friendly but don't do good workand shoud be in sales.
Makes a good story I guess. You told us it was stock 6 times so are we supposed to be mind readers or interrogate customers more?? It takes longer to strap cars down and if we strapped all down would not have got through 50 cars. Your car was impressive especially with stock air box which is testimony that ram pods are not needed. There are much lower powered GTR's have ram pods and have the noise and sucking hot air.
Adrian I have never seen NOS on dyno before and that damaged me and messed with my mind as SO IMPRESSIVE. Instant power and no lag and more power everywhere.
Thought someone could have brought something along to beat my zed, he he...
Will do it again in about a years time give us some time to recover. It will only be bigger and better.
Edited by Boosted Zed
....Ben is a great mechanic and tuner not so friendly....
I disagree! He rocks! I keep recommending Ben to everyone, hehe :devil:
Thanks for the awesome day John :down:
(already thanked abobob....with a stick of chewing gum :O (it's in the mail)) :iluvff:
Thanks John for hosting the day.
One year????
Please, can we do a BBBQ next time around. :O
The BBQ isnt worth it, when the pub up the road (2 mins drive) has such good meals.......and beers........
I tried the char grilled chicken burger, best $13 i have spent all week
Who knows, maybe next time we will have the bbq
have to agree with everyone on that john execellant day give a well done to your crew and a $5 bonas it there pay packed this week but dont ask me for the money im still trying to get more hp outa the old girl
Cheers Peter
haven't had my car tuned there, but have heard great things about ben and UAS so i certainly will be going there for a tune up, when the money presents itself ofcoarse though, lol. Needless to say, you blokes are at the top of my reccommendation list :P
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
