... The AP's will fit specific 17" rims, the ones he has done were on the cars had the same set of RAYS on each,
What size rotor, 355mm or 343mm? 343mm woudl be no drama at all on most wheels, 355 woudl be a test:)
The whole fiting inside a certain rim has a few variables. Including the design of the rim, cast, 3-piece, forged etc.
Secondly the style of caliper. The CSC upgrade on a 343mm rotor didnt fit inside my old AVS wheels. Throw the WEDS on they cleared perfectly. I have trial fitted a few different combos and measured a few up, and the caliper does play a large part. Surprise the 4 pot AP caliper on a 343mm rotor fitted inside the AVS wheel, though the AP 4 pot caliper i trial fitted was only meant for rotor sizes up to 330mm
My friends Alcon 4 pot brakes cleared my old AVS Model 5 wheels but not my AVS Model 6 wheels ?!?!?! SO, who can say :)
Some calipers saddle the rotor a lot better. The 8 pot Brembos i mentioned actually fitted on a 330mm rotor, and still fitted inside std R32 GTR 16" wheels..so look at your car on a case by case basis.
You can get manufacturer drawings for many of the calipers....measure it all up and decide what you want, then go shopping.
I know which caliper and rotor i want, problem is i cant really afford the $6,500 for a front brake upgrade, so continue to hunt around for a better compromise :)
And truth be told, a 240rwkw R32 GTST doesnt need big brakes for 4-5 laps of a circuit, even one liek Sandown which really tests brakes :P
  • Replies 57
Posted Images
My friends Alcon 4 pot brakes cleared my old AVS Model 5 wheels but not my AVS Model 6 wheels ?!?!?! SO, who can say :P
And truth be told, a 240rwkw R32 GTST doesnt need big brakes for 4-5 laps of a circuit, even one liek Sandown which really tests brakes :(
Just to throw some extra info to this discussion, I was out at Calder today to shake down my R32 GT-R for the first time before our motorsport c'ship begins in February.
I have fitted a front and rear CSC upgrade consisting of 355*32 mm 6 pot fronts and 343*28mm rears with 2 pot caliper.
This setup costs roughly the same as an AP front upgrade when you consider braided lines and pads.
They are locally made and Sebastian at CSC supports his product well.
I can honestly say the set up is very impressive, and very well balanced give the complete upgrade of front and rear brakes components.
At Calder I brake from 200 (up to 230kmh if I get the front straight entry right) every 30 seconds. I am using DS3000 pads up front and Hawk HPS pads at the rear.
It's a fantastic setup and copes with the constant heat very well give the short (1.05-1.08 sec lap times).
The only issues I'm having is with the RE55 SR tyres I'm running it seems the stub assembly is flexing under load and giving me a bit of pad knock off. Hardly a major issue as it's not that much.
Of course I'm biased here but it's real world testing and you do a lot worse for your hard earned cash. :)
Regards
Andrew
Edited by BBGTR
How is to drive compared to the WRX :)
Your brake uprgade looks pretty goods, but the cost of the kits is what i will spend over 2 years of track days :domokun: I need to be smarter with my money so i can afford better mods :)
Be good to see after 10-12 track days how the pads are wearing, rotors etc etc.
Your brake uprgade looks pretty goods, but the cost of the kits is what i will spend over 2 years of track days :)  I need to be smarter with my money so i can afford better mods :)
It's completely different. I love the flames out the back though :domokun:
It's a bit hard to get used to it when you're watching out for V8 Supercars coming past you at 270kmh :)
Yep, it's a large outlay but I like to balance my go with some serious slow.
I got 14 events out of the CSC rotors on my Sti using Hawk Blues so I'll be interested to see how these go.
Regards
Andrew
Edited by BBGTR
Did the pads show even wear, indicating that the leading/trailing piston size was on the money.
The pads didnt taper top to bottom indicating that the caliper is deflecting etc etc? Little things like that are why im hesitant to do the CSC 343mm 4 pot upgrade. Im sure they are ok, but i am too tight to spend the money...
Plus i want Alcons, but beer pocket, Moet taste ...i mean i want to feel aroused when i look at my brakes:)
Pad wear rates look good - both leading trailing and top to bottom. I had no issues with the 343 mm setup on the rex after 2.5 years of track use either.
It all comes down to the ALCON bling and whether it's worth the extra $3k.
Getting a woody while looking at car parts means it's therapy time!! ;)
Regards
Andrew
Bought from NENGUN at $505.00 and arrived from Japan in less than a week. I brought my last set from RaceBrakes and cost the above just for the fronts a Ferodo compound.  The CC-X's are Track orientated but I can still drive home on. Less dust than the Ferodos.
After a couple of trips to Mallala i am very happy with them and am now considering upgrading to a 6 pot Endless upgrade kit. Race brakes recommended APs and although I have seen them on skylines the Endless rotors and calipers look appear comparable slightly better priced i.e I could get front and rears for the same AP or Brembo 6 pot front only upgrade. The front/rear  balance should be evenly matched. Looking at doing the classic Adelaide this year and should have fitted by then.
The endless pads are pretty good. I have just bought a set of the next one up from the CC-X (CC-R) the only downside to them is that they are not suitable for street at all, but should give nice performance on the track. if anyone is after another set of the CC-X i can get them for around $430 delivered (for a full front and rear set), the CC-R are a little more pricey, not sure how much they were off the top of my head.
Well i just ordered a EGT probe for my data logger. I will hook it up to the front right (away from the wastegate vent) hub and see what temps i get around Sandown. I will then throw on a new undertray i have fo rmy car which has ducting for brakes and i will see if there is any change in brake temps and performance.
If some effective ducting means the brakes out last the coolant/oil temperatures then ill be stoked.
Will post data printouts when done...provided i dont put it upside down on the back striaght :P
Cooler is in the drivers side inner guard, where is it going....ummm still working on that one,i have an idea or two from looking at an R31 GTSR Grp A car, but willsee if it fits how they had it plumbed up....very similar to what that fella was telling you about coolers and locations :)
you are making me all insecure about my placement now bloodnut! but on the GTR the brake ducts are just for show. until the swiss chese job was done the one that houses the oil cooler just went into the front bar, then no-where. I have at least cut off the backing plates. I like my oil cooler spot though cause it works so well.
Beer Baron - think about the air pressure caused by the rotating front wheel, and the positive pressure caused directly in front of it.
So if you cut holes in the inner guard for the cooler to eject the air, it doesn't do much because of the relative positive pressure behind it.
It's better to cut a side exit in the bumper where the air flow across it will be a negative pressure drawing out the hot air
agreed. but dam it looks ugly. but it wasn't just holes cut in the liner. there is an aluminium duct built around the core to force the air through the oil cooler, then out through the back. it definately works, but i agree it could work better with a side exit, but again...damn...
Sorry, i have a spreadsheet at home with all the Nissan caliper sizes and master cylinder sizes, rotor sizes etc, but am working in Singapore at the moment :(
But if you do a search you will find the piston sizes, as i have posted them before.
Roy,
I tried to find the post you mentioned, but failed rather miserably. Can you point me in the irght direction?
Cheers
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
