  • 3 weeks later...
Had my r32 dyno tuned today.
Hypergear atr43ss1 turbo with tial 38mm external wastegate
Hybrid side mount exhaust manifold
Cooling pro return flow intercooler
Jjr 3 inch turbo back exhaust with high flow cat
Bosch 550cc injectors
Bosch 040 fuel pump
Nistune
Pod filter
Made 297.6hp at 18psi of boost
A little lagier than I was hoping but it pulls well on full boost.
  • 3 weeks later...
89 gtst
jjr/kkr430
gtr injectors
gtr pump (i think)
z32 afm
China cooler
full 3 to 3.5in exhaust
Dr drift remap (from another car , was put in just for a temporary thing)
226.1rwk @20psi
Edited by toffy
  • 1 month later...
  • 3 weeks later...
1990 rb20det 180xxxkm
Stealth Return Flow Intercooler
High Flowed Steel Wheeled 34 Turbo
3inch Turbo Back
Split fire Coil Packs
K&N Pod
Standard Intake
Walbro Fuel Pump
Boost T set at 1bar of Boost
Standard Computer
259.7hpatw/193.6kwatw
1993 rb20det
150,000
fmic
power fc
z32
stock internals
800cc injectos
walbro fuel pump
3in dump to straight through
14 pound
apexi ax5370b
163kw :(
Edited by thomas.mcsherry
  • 1 month later...
  • 3 weeks later...
Ran my rb 2.2 for 4 years of solid drifting over 60 events in various stages from 98 ron to full e85 and a heap of different turbo and power setups, below is the last dyno and finally a main bearing went a couple of weeks ago so sold it off... but will put up results. prob forget a bitta stuff
Dyno was a hubber: 550hp and 600 nm at 23psi on full e85
Rb22
port and polished head
race springs
HKS 264 in / ex cams
Adj cam gears dialled in
rb25 crank rb26 rods
arias forged pistons 82mm
cosmetic metal head gasket
extra capacity sump
splitfire coils
vipec v88 ecu
1000cc ID injectors
full fullsetup, braided lines walbro lift pump 2 x bosche ext
aeromotive filter + fuel pressure reg
plasmaman plenum
greddy intercooler
greddy oil cooler setup
PWR rad
6boost
Gtx 3076 .82 rear
Tial 44 ext gate
rb25 box
both extreme and exedy clutches used
custom exhaust 3" to 3.5" twin pipes straight through
restrictors in head, massive head to sump drain, breathers from covers to catch can and drain back to sump
etc etc
Hey all, my r32 gtst type m '93
Standard engine internals
Stock Coilpacks
Stock injectors
Unknown turbo back exhaust 3inch/4inch tip
T04e turbo 18psi
Big FMIC
Gay pod filter (WTB stock air box)
Turbosmart wastegate w/ screamer... Ha :/
Manual boost tap
HKS BOV to atmo (making car stall like a bitch)
Tuned by ChipTorque
208kw... Yet to install Yellow Jacket coils and 550cc injectors and Turbosmart Kompact plumb back BOV
The RPM scale is a little off on the dyno also done to SAE correction on a Dyno Jet. The pulls were made to 8k rpm max boost was set to 18psi on 91 pump gas. The RB20 is in a S14. Wish I wasn't so scared to go over 8k :(.
Persicion SC61 turbo with stage 5 exhaust wheel
Griffen FMIC
Tomei 270 cams
Tomei valve springs
Tomei head gasket
ARP head studs
AEM S2 EMS
HK$ evc 4
Apexi GT spec exhuast
Sard 800cc injectors
Supra TT fuel pump
Rips intake manifold
Blitz dual surge BOV <~~~POS
  • Like 1
  • 4 weeks later...
'89 R32 GTS-t
Greddy FMIC
HKS filter
HKS low mount exhaust manifold
HKS wastegate
HKS 3" TBE
KKR430
Z32 AFM
444cc GTR injectors
BOSCH 040 fuel pump
237.6kw on 19.5
Lost the dyno sheets :( but it was done at PowerTune in Sydney
R32 gtst RB20DET
Deatchwerks 650cc injectors
Deatchwerks 320 lph fuel pump
Yellow jacket coils
Z 32 afm
bellmouth dump & 3 inch all the way
big fmic
Nistune
Rb 25 turbo @ 14 psi
180 killerwasps on a safe tune ( a little rich)
  • 1 month later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
