i got my car tuned at unigroup as well.. power was 186kw @9psi
i wasnt prepared to run more than 10, so boost peaked at 10 but peak power was made at 9psi. tuner said approx 200 probably would have been made with 12-13psi..
i asked for a conservative tune (which i got) as i prefer to drive hard and never worry about tune related problems...
stel, do you have the graph with AFR's? post it up if you do...
sorry mate,
didnt get the graph with afrs (STUPID!!!)
they were about 12.4 at the start, gradually dropping and staying at 12 flat.
The 206.6 is a conservative tune as well.
I basically told them that i want to be able to drive it hard without anything going boom.
nice work
I managed 210rwkw with 13psi, 95 ron fuel and toluene, and yeah the supporting mods (exhaust, powerfc, fmic, standard turbo etc)
I'd still get your fuel pump replaced... all that standard one has gotta do is drop pressure while you're on full song and you're f**ked....
sorry mate,
Oh well next time you are around there go and get one printed off!!
my afrs start off like yours but then drop and stay a bit below 12 more like 11.8 so even more grandpa style than yours :D
i have changed my fuel pump already too.. if i were you i would change it as everyone else (and im sure unigroup) would reccomend you do, just for peace of mind.
cool, u coming on the cruise 2morrow?
i changed my fuel pump myself and it was the most painful annoying thing i ever did and my shouler hurt for weeks after plus my skin peeled off so pay someone to do it :P
Edited by siksII
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
