I doubt anyone here would argue with this, handy info too IMO as ive seen it asked a lot.
So many happy customers from all reports across this forum.
This is NOT an intended business plug in anyway.
Whenever someone asks for a clutch, this man comes up, then someone asks for his details.
So just getting in first :)
RACE CLUTCH - Jim Berry
26 Gladys St
Stones Corner QLD 4120
Phone: 07 3847 9999
NB: Jim likes to talk clutches. A lot :)
https://www.sau.com.au/forums/topic/103268-need-a-new-clutch/
lol i hear you need to budget at least one hour out of your day...  but his clutches are worth it.  :lol:
Damn right they are worth it.
And he does go on a bit, but as he said to me. Its a lot of money for some people to spend, he just wants to explain everything to them so they have all the information to make the right decision. If you dont understand something he tells you. Say I said, why do I need to do 'x' he explained why, and the best ways of doing it etc. He actually rang me at 10am on a Saturday morning as that was most convenient for me.
Oh and if someone answers the phone 'italia spares' its the same shop, just ask for Jim.
  • 3 months later...
I got the FULL MONTY which is there top of the line single i also did not do exchange so he had to source all parts for me $1100-1200 including postage to sydney i think it cost. Dam good price most liky about $800-900 if you have the clutch plate and the rest.
I've had a Jim Berry "FULL MONTY" as he calls it, set up in my R33 for 6 months now.
couldnt be happier.
It's not overly heavy even though it has a 3400kg clamping pressure. (my friends exceedy brass button clutch's pedal is hevier)
So far its worked brilliantly!! Would highly recomend this set-up to anyone wanting a new clutch that can cope with nearly anything you throw at it.
the other good point is that once it does eventually wear out, send it back to Jim an he'll remake the clutch again at a much lower price than the original purchase.
mine costed me $1100 from memory. well worth it! And yeah, set aside some time when you call Jim, he does explain every detail of the pro's and con's of various clutches an common faults etc etc etc
cheers
Berin
  • 1 month later...
I've just had a new Jim Berry "Full Monty" clutch installed in my R33 and I must say that it practically feels like a stock clutch to drive...it's bliss compared to my twin plate.
I plan on taking my car to WSID tonight (weather permitting) and if this clutch holds up and doesn't slip as Jim assured me it wouldn't, then i'll be mighty impressed.
  • 1 month later...
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
