  • Replies 1.5k
Posted Images
f**k off idiot, just because Michael lost to a better man you cant diminish what Alonso achieved, grow up and deal with it
I am more than intitled to revel in his victory, if you dont like it piss off back to yout hole.
Resorting to calling people names because the team you support lost is juvenile and shows how infinitesimally small your appreciation and understanding of this sport acctually is
I hate F1 weekends, you guys always start the discussion early and I have to just avoid this thread until after the race, I refuse to watch a race until i've watched the qualifying as that's what creates the picture for the entire weekend.
I really hate Ch10's coverage for the F1, I wish that Ch10 (or even Ch7) would just use the entire iTV footage for the Qualifying and Race meetings without cutting back to the current Ch10 commentary. They cut over to the iTV broadcast literally 2sec after the race started, they cut the beginning and end of interviews just so Mr Diffey could get his piece in. Even SpeedTV in America has better coverage despite their silly accents grr!
Anyway here are some short videos:
Fisichella makes a mistake at turn 1
Rosberg Accident
Raikkonen vs Schumacher
Post Race Interview
Will edit above with the post race interview in 15mins when it finishes uploading or you could always just subscribe to my account on YouTube and be notified of all new videos I upload.
Edited by benm
haha ok champ :)
you should check out some of your buddies posts :sorcerer:
beaten by a better man... thats the best post yet
thanks benm, much appreciated as always :)
He smashed into the back of Webbers car on the first corner. Webbers entire rear wing disappeared (out of the race) and Rosbergs front wing and suspension were damaged... not pretty on that final kink before the main straight.
thank you Alonso, my hat goes off to you
you now truly are the best going around
PS. now piss off you cheating Nazi bastard and dont ever come back
it might have been easier to take your comments if you werent childest.
i do not like Alonso but i can admit that he is a good driver (you dont just win races on luck)
just beacuse you dont like M.S doesnt give you the right to say rasict comments about him.
GROW UP!
and accept that MS is a good driver you dont win all he has without skill
gold
he's good in terms of knowing his stuff...but personally he shits me to tears!
he drivels on endlessly with big technical terms (and yes i do understand them, so thats not why i dont like it)...personally i think he sucks a lot of excitement out of the races he commentates
they should just do as you said and stick to iTV for the entire race.
only thing is...I'm tempted to go back and count the amount of times the words 'button' or 'jensen' were used by the iTV guys....I think they beat their own record last night
thanks benm for the clips, man, kimi vs shuey.....that took BALLS
the rest of you quit bickering like little kids, just enjoy the fact Alonso won Drivers Championship if you are his fan and enjoy the fact that MS is one of the best drivers in the history of F1.
JapCab, if "f off idiot" is the best retort you can come up with then you need to do some growing up, makes you sound like a retarded teenager..........but then again, it's just my view, ignore it if you want.
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
